POV-Ray : Newsgroups : povray.windows : GPU Server Time
11 May 2025 08:42:09 EDT (-0400)
  GPU (Message 1 to 8 of 8)
Subject: GPU
Date: 11 May 2011 04:40:01
Message: <web.4dca4b062b2eba78b677d1e90@news.povray.org>
When checking the CPU and graphics card performances, temperatures etc. while a
picture is being rendered I realized that when the render window is hidden or
POVray is minimized, the GPU is still working with full throttle. CPU is always
about 100%, this is OK. But why the GPU, too? I'm not an expert of hardware so
sorry for the question.
Subject: Re: GPU
Date: 11 May 2011 07:00:00
Message: <web.4dca6b54eed3d57a9a1bcfb90@news.povray.org>
Surely some mistake.  Everyone knows povray is a CPU-only math surfaces
raytracer and GPU is just for games...
Subject: Re: GPU
Date: 11 May 2011 14:16:39
Message: <4dcad287$1@news.povray.org>
"nemesis" <nam### [at] gmailcom> wrote in message
news:web.4dca6b54eed3d57a9a1bcfb90@news.povray.org...
>> while a
>> hidden or
>> always
>> hardware so
The obvious questions in my head would be:
1) How are you measuring GPU utilization (and could that method be misled
somehow) and
2) What else is running on your computer (i.e. what happens when POV-Ray is
off)
No.
Subject: Re: GPU
Date: 12 May 2011 04:05:01
Message: <web.4dcb93b6eed3d57ab677d1e90@news.povray.org>
> >> while a
> >> hidden or
> >> always
> >> hardware so
> somehow) and
> off)
> No.
I use the Open Hardware Monitor utility (http://openhardwaremonitor.org/) that
among others shows the CPU and GPU performances, etc. When POVray is rendering,
the GPU temperature clearly raises by about 15 deg.
Subject: Re: GPU
Date: 12 May 2011 12:19:59
Message: <4dcc08af@news.povray.org>
How much does the CPU temperature go up? Could it be spill-over heat?
   "Coding without comments is like
    driving without turn signals."
Subject: Re: GPU
Date: 13 May 2011 03:35:34
Message: <4dccdf46$1@news.povray.org>
Am 12.05.2011 18:19, schrieb Darren New:
Sounds line the most plausible thing to me; POV-Ray typically gives the
CPU a pretty hot time; if airflow in the casing is poor, the GPU cooler
will breathe in hot air, greatly reducing its efficiency.
Subject: Re: GPU
Date: 13 May 2011 04:30:00
Message: <web.4dccead9eed3d57ab677d1e90@news.povray.org>
Good point. To check this assumption I started some very computation-demanding
quantum chemistry calculations without graphics, and it also raised the GPU
temperature by about 14-15 deg C.
Obviously this is very hardware-depending. You may want to check it in your
compy. The above mentioned Open Hardware Monitor is very friendly, it does not
install anything, you have simply to copy
it to somewhere and start the exe file.
Subject: Re: GPU
Date: 13 May 2011 22:25:08
Message: <4dcde804$1@news.povray.org>
A simple kludge that can help you in this case:
Using some light cardboard or heavy paper, and some glue, make a duckt
going between the fan of the video card and some opening of the case
from whitch it can get fresh air.
Next, place another peice as a wall between the CPU and the video card
to force the heated air away from the card.
You may also make a funel connecting to the CPU fan to help limit it
re-aspiring it own heated air. Fashion it so that it goes toward some
opening in the case or an intake fan.
anything else...
If you use corrugated cardboard, it's also somewhat effective at
reducing the noise level a little.
