POV-Ray : Newsgroups : povray.windows : How to run pvengine on background? or Where is povray.exe? Server Time
15 May 2025 05:23:05 EDT (-0400)
  How to run pvengine on background? or Where is povray.exe? (Message 1 to 9 of 9)
Subject: How to run pvengine on background? or Where is povray.exe?
Date: 11 Aug 2008 10:10:00
Message: <web.48a04729aa70066a1f9fd8c60@news.povray.org>
Hi;
I have an executable file which takes some arguments, create a .pov file, render
it and then save it as bmp. I'm calling this executable file from another code
written in csharp. I want the povray program not to be seen when the code calls
it, just run on the background.
In my executable file's source code, the command "povray" was used. After i
installed povray, i saw the program has not "povray.exe" but "pvengine.exe". I
changed povrays into pvengines, then compiled again I could be able to run it,
but i had the problem.
What can i do? Can i find the povray.exe file? Can it solve my problem?
p.s. : The executable file is too old, so the version of povray.exe file is not
important.
Subject: Re: How to run pvengine on background? or Where is povray.exe?
Date: 11 Aug 2008 19:21:46
Message: <48a0c98a@news.povray.org>
Can nous illumina en ce 2008-08-11 10:07 -->
> Hi;
> important.
Start POV-Ray minimised, and set to only run one instance, and don't terminate
it after the first render. You don't need to save the image yourself as POV-Ray
does it itself. Unless you set it otherwize, the output format under Windows
default to BMP.
You may first start POV-Ray, dismiss the splash, minimize it, then start your
application.
Go to Options|Keep Single Instance and make sure it's checked.
HAMMER:  Originally employed as a weapon of war, the hammer nowadays is used as
a kind of divining rod to locate expensive bike parts not far from the object we
are trying to hit.
Date: 12 Aug 2008 03:15:00
Message: <web.48a137f47e82ff3b1f9fd8c60@news.povray.org>
> > Hi;
> > important.
> default to BMP.
> application.
> Alain
> are trying to hit.
Thank you very much Alain. Your solution is artful, but actually it doesn't
block the running of GUI of Povray, just hides it.
I solved it in another way.
I installed cygwin. Then i downloaded unix source file of POV-Ray and compiled
it by cygwin. It created the povray.exe which has not any GUI. Then i found two
required dll file on Internet: cygwin1.dll and cygz.dll. I copied them into the
same folder with the povray.exe. So the povray.exe now works on Windows XP
without any GUI.
I seems a bit complicated but completely solves the problem. It doesn't require
advanced Unix knowledge because read_me file of the source code shows the Unix
codes required for installing POVRAY.
Date: 16 Jan 2009 10:15:00
Message: <web.4970a3cd7e82ff3b16fff8b30@news.povray.org>
> > > Hi;
> > > important.
> > default to BMP.
> > application.
> > Alain
> > are trying to hit.
> without any GUI.
Hello, Can.
I would greatly appreciate if you could send to me povray.exe as an attachment
to an email.
This way I would save a lot of work, and I don't need to install cygwin,
compile,...
My email address is: lui### [at] gmailcom
Thanks in advance
Luigi
Date: 21 Apr 2009 11:15:01
Message: <web.49ede2097e82ff3be23a9cd0@news.povray.org>
> > without any GUI.
Can you say how you have compiled the source ?
Date: 21 Apr 2009 12:30:01
Message: <web.49edf3637e82ff3be23a9cd0@news.povray.org>
Indeed I would like to know what are the necessary librairies to install such as
the compilation works.
Best regards.
Christophe.
Date: 21 Apr 2009 12:40:00
Message: <web.49edf68a7e82ff3be23a9cd0@news.povray.org>
What are the libraries needed to compile POV-Ray ?
Best regards.
Christophe.
Date: 21 Apr 2009 14:00:01
Message: <web.49ee09637e82ff3be23a9cd0@news.povray.org>
Finally, everything is ok.
Date: 21 Apr 2009 16:55:01
Message: <web.49ee31ba7e82ff3be23a9cd0@news.povray.org>
> Best regards.
> Christophe.
Indeed I've done it.
