POV-Ray : Newsgroups : povray.windows : Getting I/O restriction prohibits errors Server Time
5 Feb 2026 04:36:13 EST (-0500)
  Getting I/O restriction prohibits errors (Message 1 to 3 of 3)
Subject: Getting I/O restriction prohibits errors
Date: 3 Aug 2006 18:10:00
Message: <web.44d273fd4d370860195eec9d0@news.povray.org>
I get I/O restriction errors on a few of the textures before pov-ray
renders. Can I go to the options and check no restrictions or will this
cause a problem?
Thank you!
Subject: Re: Getting I/O restriction prohibits errors
Date: 4 Aug 2006 12:30:00
Message: <web.44d375c5eca65b2c195eec9d0@news.povray.org>
> cause a problem?
> Thank you!
 Well I went ahead and checked the no restrictions and things seem to be
okay. I was really using povray there for a bit but kind of got away from
it fighting with poser 6. I did note that poseray was updated.
Date: 7 Aug 2006 21:39:50
Message: <44d7eb66$1@news.povray.org>
>> cause a problem?
>> Thank you!
You can edit the "povray.ini" adding "Library_Path=" pointing to your external
folder. You also need to edit "pvengine.ini" file and add the same path in the
[Permitted Input Paths] section (the first one).
This will allow you to keep I/O restrictions active and access your files and
textures. Those restrictions are there for security reason. Usualy, removing
those restrictions don't cause any problem.
A true friend is someone who reaches for your hand
and touches your heart.
