POV-Ray : Newsgroups : povray.windows : v3.6 binary for Windows does not run on Windows95 Server Time
2 Mar 2026 15:32:37 EST (-0500)
  v3.6 binary for Windows does not run on Windows95 (Message 1 to 5 of 5)
Subject: v3.6 binary for Windows does not run on Windows95
Date: 22 Aug 2005 15:40:00
Message: <web.430a2962bd1661ef40d52b80@news.povray.org>
The Windows section of the download says, "The 32-bit version requires at
least Windows 95 ...", implying that it will run on Windows/95; however the
current v3.6 binary does not.  It installs properly but when you attempt to
start povray,  an error message-box appears saying somthing about povray
being linked to shell.dll which is missing export GetSpecialFolderNames."
It would be helpful to have a binary that continues to run properly on
Windows/95, thanks.
Subject: Re: v3.6 binary for Windows does not run on Windows95
Date: 22 Aug 2005 15:58:05
Message: <430a2e4d$1@news.povray.org>
> Windows/95, thanks.
You should install the strongly recommended Internet Explorer 4 if you
haven't.  A proper shell.dll certainly is included with it.  I don't know if
it is included in IE 3 or not (the download page says IE 3 is required, that
might be outdated, I just don't know.)
The function you are missing probably is "SHGetSpecialFolderPath" as there
is no such thing as "GetSpecialFolderNames" anywhere in the POV-Ray for
Windows source code.
	Thorsten
Date: 23 Aug 2005 15:55:00
Message: <web.430b7ed2c5e6da1a40d52b80@news.povray.org>
> > Windows/95, thanks.
>  Thorsten
This system has IE 5.0 installed.  The unsuported function POV-ray
references is actually "SHGetSpecialFolderPathA" (the non-unicode version
of that Win32 API function).
Date: 23 Aug 2005 16:04:12
Message: <430b813c@news.povray.org>
>>>Windows/95, thanks.
>> Thorsten
Sounds like Shell32.dll was replaced by an older version. I'd recommend
reinstalling IE5 or downloading and installing IE6 (if it runs on 95...)
~Mike
Things! Billions of them!
Date: 24 Aug 2005 10:40:00
Message: <web.430c865fc5e6da1a40d52b80@news.povray.org>
> >>>Windows/95, thanks.
> >> Thorsten
> ~Mike
The machine had IE 4.0 when I installed POV-Ray v3.6 (replacing V3.0).
When I encountered the "GetSpecialFolders..." error I installed IE 5.0,
knowing that IE upgrades sometimes fix such things.  At this point, other
than reporting this incompatability to the POV-Ray team, there is no point
in diagnosing the problem further.  The grade-school kids who use this
system can make do with v3.0.
