POV-Ray : Newsgroups : povray.windows : WinXP & intel P4 only 50% used Server Time
1 Apr 2026 00:47:40 EDT (-0400)
  WinXP & intel P4 only 50% used (Message 1 to 10 of 14)
Subject: WinXP & intel P4 only 50% used
Date: 5 Oct 2004 03:45:00
Message: <web.41625040c0c3c5cc6cebd8020@news.povray.org>
Hi.
I'm using POV on a P4 machine with 3.2 GHz under winXP.
Switching the render priority to highest, i only get a processor usage of
50%.
P4 processors are splitted into 2 processors. how can I tell my POV to use
both parts?
Greetz from Germany!
DjR
Subject: Re: WinXP & intel P4 only 50% used
Date: 5 Oct 2004 04:25:02
Message: <cjtlju$29m$1@chho.imagico.de>
DocJunioR wrote:
> Hi.
> 50%.
> both parts?
P4 processors are single processors just like others.  They can just
represent themselves to the system as two virtual processors.  If your
OS reports 50% use then this is not the real processor use.  POV-Ray
does not use multiple processors (neither virtual nor real) so the only
way to use them is to run several instances of POV-Ray (either manually
or automatically).
Last updated 23 Sep. 2004 _____./\/^>_*_<^\/\.______
Date: 2 Nov 2004 16:30:00
Message: <4187fc58$1@news.povray.org>
I noticed the same behaviour.
Do you mean there is no way for POV to use the whole power of the processor
and we have to wait twice the time we should ? Rats !
cjtlju$29m$1@chho.imagico.de...
> DocJunioR wrote:
>> Hi.
>> 50%.
>> use
>> both parts?
> represent themselves to the system as two virtual processors.  If your OS
> reports 50% use then this is not the real processor use.  POV-Ray does not
> use multiple processors (neither virtual nor real) so the only way to use
> them is to run several instances of POV-Ray (either manually or
> automatically).
> Christoph
> POV-Ray tutorials, include files, Sim-POV,
> HCR-Edit and more: http://www.tu-bs.de/~y0013390/
Date: 2 Nov 2004 16:43:26
Message: <4187ff7e@news.povray.org>
  Didn't you read what he said?
  P4 is just one processor, not two, and POV-Ray is using (almost) 100% of
its power.
  You will not get basically any advantage by rendering in two threads
because the two threads will mostly be interleaved by the CPU, not run
in parallel.
  That is, in other words: Even if you run two instances of POV-Ray,
each one rendering half of the image, the total rendering time will
not speed up considerable. One instance is already using the maximum
capacity of the CPU.
  Now, P4 has this funny thing called hyperthreading which makes the
processor look like two and can, with some tricks, be used to speed up
a program (almost as if it was run by two true processors). The trick
is to create two threads and run eg. integer math in one (calculated
by the ALU) and floating point math (calculated by the FPU) or MMX math
(calculated by the MMX processor) in the other.
  However, POV-Ray can hardly use this trick even if it wanted to because
most of what it does is floating point math, and there's only one FPU to
do it. And POV-Ray *is* running through the FPU at full power.
  Windows makes it look like it is only using 50% of CPU because P4 is
emulating two CPUs and Windows makes a simple (but basically wrong)
calculation about how much of the two (virtual) processors POV-Ray is
using. POV-Ray cannot use the "other processor" because there's no
other processor. It's just a kind of "virtual" processor (which another
process not needing the FPU could perhaps use).
  So no, if the POV-Ray benchmark is being finished in 30 minutes in
your P4, there's no way it can finish in 15 minutes no matter what you
do. That's not what the "two processors" mean.
Date: 3 Nov 2004 19:09:51
Message: <4189734f$1@news.povray.org>
DocJunioR nous apporta ses lumieres ainsi en ce 2004-10-05 03:41... :
>Hi.
>50%.
>both parts?
>DjR
It is possible to disable hypertreading. It must be somewhere in the
bios settings. I saw some benchmarks results that where faster with it
disabled.
Date: 3 Dec 2004 14:18:06
Message: <41b0bbee$1@news.povray.org>
This is interesting. On my Athlon XP 2000+ the CPU usage
goes straight to 100% and stays there until the image is done.
At least with the AMD processor Windows XP reports
accurately ;-)
H
news:4187ff7e@news.povray.org...
processor
> its power.
> in parallel.
M()}}
Warp -
Date: 4 Dec 2004 02:39:18
Message: <41b169a5@news.povray.org>
> accurately ;-)
  How many processors do you see in the task manager? One.
  With P4 you see two.
  It's not about accuracy.
Date: 6 Dec 2004 17:30:49
Message: <41b4dd99$1@news.povray.org>
Well it is accurate anyway ;-)
news:41b169a5@news.povray.org...
> > accurately ;-)
M()}}
Warp -
Date: 1 Feb 2005 04:45:00
Message: <web.41ff4eb9d47b0c5bc4fb1c850@news.povray.org>
> its power.
> in parallel.
That's not quite completely correct.  A P4 with hyperthreading is a single
physical processor but two logical processors.  Logical and virtual are not
to be confused.  Long story short while it's true the two logical
processors do share some of their physical resources so it's not true SMP,
it's fairly close in most aspects due to the way the pipeline is designed.
It's more than emulation.  Overall it's a more efficient processor
(assuming you have software that can utilize it).  So when windows is
reporting that it's only using 50% of it resources that's mostly true and
also why you can run other programs without lagging them or POV (POV keeps
utilizing it's full logical processor while the other programs use
resources from the other).
Actual benchmarks have shown that if you run 2 instances of POVRay on a
hyperthreading machine (one instance on each logical processor, each
rendering half your image) you will have the completed image in around half
the time (assuming the two halfs take about the same time to render).
Try SMPov (I use it with my render farms and it works pretty good), it's
fairly easy to set up and run.  The one downside to this sort of thing is
when you're doing radiosity you can get seams where the images were put
together and with photons I'd suggest saving a photon map and loading it to
save on preprocessing time.
Date: 1 Feb 2005 06:54:27
Message: <41ff6df3@news.povray.org>
  I find that hard to believe. Either that is not true, or the claim
that two processes can't use the FPU at the same time is not true.
  If I'm not mistaken, one POV-Ray thread could perform integer math
at the same time the other POV-Ray thread is performing FPU math. But
when the first one needs the FPU it has to wait for the second. Since
POV-Ray uses the FPU quite heavily, I find it quite hard to believe
that running it in two threads would drop the rendering time to half
(unless the P4 *really* can run two FPU threads at the same time).
  I am ready to believe that the total rendering time drops by
some percentage (because POV-Ray naturally performs other operations
than just FPU opcodes, naturally), but I would be surprised if this
percentage would be anything close to 50%.
  If it really is close to 50%, then someone has to explain me how
is that possible.
