POV-Ray : Newsgroups : povray.windows : How to close message window? Server Time
3 Mar 2026 18:34:35 EST (-0500)
  How to close message window? (Message 1 to 6 of 6)
Subject: How to close message window?
Date: 29 Nov 1997 21:22:45
Message: <Pine.D-G.3.91.971129211605.6447A-100000@unix1>
I've looked but all I can find is how to clear messages.  Is there a way
to close the message window in PovWin?  I don't usually do a complete
render unless I think the scene's reasonably correct and hit Alt-G when
I've seen the part I'm looking for.  I probably should be specifying the
region to render with command line switches but that takes too much
foresight.  :-)
Any help appreciated.
    Thanks,
      Alan Corey
Subject: Re: How to close message window?
Date: 30 Nov 1997 05:22:24
Message: <65rep0$dvm$1@melchior.Cuivre.FR.EU.ORG>
That depends. If you want to _close_ it, no way.
If you just want it to stop appearing under your scene script, there
is an option available by clicking somewhere (but where?) with the
right button. I cannoy be more precise, since I use POV-Ray very often
but Windows very rarely.
Friendly yours,
  B-o-b
bob### [at] casimirrezelenstfr -- Linux, POV-Ray, LaTeX
Date: 30 Nov 1997 12:12:50
Message: <Pine.D-G.3.91.971130120109.7008A-100000@unix1>
y
> Friendly yours,
>   B-o-b
Thanks.  I'm not used to things appearing in a right-click menu and not
anywhere else (including Help).
FYI: You right-click on the editor window and select "hide messages".
I tried the DOS version (under Windows 95 but not at a "Command Prompt
Only" boot) and it looked like it was only about 10% faster.  Speed would
be the only reason I'd use it but for 10% I prefer Windows.  Supposedly
the Linux version may be faster which I find hard to believe.  I thought
*everything* ran slower under Linux.  :-)
  Thanks again,
   Alan Corey
Subject: Speed (was Re: How to close message window?)
Date: 11 Feb 1970 08:56:10
Message: <01bd36ec$1d80bd40$181657a8@W_tristan.gb.tandem.com>
Some possible reasons for speed differences.
Dos doesn't do multitasking so you've got no other code using your cpu's
time (except interrupts - eg timer and keyboard). A dos box still doesn't
take account of threads, so it runs faster than windows. to let other
programs in windows get a look in when you have a dos box, the timer
interrupt swtiches from the dos box to windows after 50ms - each dos box
gets 50ms, then windows and windows programs get a whole 50ms between them.
Dos and Linux should have little speed difference between them. Most of the
time consuming code doesn't have anything to do with the Operating System,
the only stuff that has any noticeable effect is memory allocation and
deallocation because it is the only thing that the OS is asked to do a lot
of during rendering. Since Dos has evolved quite a bit, I expect it's
memory operations are quite similar in speed to Linux (at least the OS
under the Win95 GUI is probably faster than Dos6.22 - which is where the
hype about win95 being faster than dos came from - dos6.22 is unoptimised,
the basic OS under the win95 gui is quite efficient, but the command prompt
is faster than windows due to lack of threads).
Tristan Wibberley
(Remove the '.NO_LUNCHEON_MEAT' from my
email address to reply.)
Alan Corey <cor### [at] unix1gccmassedu> wrote in article
<Pine.D-G.3.91.971130120109.7008A-100000@unix1>...
way
> Friendly yours,
>   B-o-b
  Thanks again,
   Alan Corey
Subject: Re: Speed (was Re: How to close message window?)
Date: 11 Feb 1998 11:27:36
Message: <m3g1lq9kef.fsf@pele.ml.org>
"Tristan Wibberley" <tri### [at] compaqcom> writes:
<goggles> You apparently don't have a clue. First off, from personal
experience there's a 10-20% speedup on the same hardware. Secondly,
the dos memory handling stuff isn't even *close* to Linux. Remember
extended and expanded memory? Those concepts are still in there, just
hidden. On top of that, you've got the gui eating up a good 12M of
your memory.....I've run Linux on an 8 meg machine without a problem.
Try using Linux for a while, and maybe reading the kernel development
archives, before you go making claims like this.
Shalon Wood
People who do stupid things with hazardous materials often die.
--Jim Davidson on alt.folklore.urban
Date: 12 Feb 1998 04:49:56
Message: <34e2d29d.0@news.povray.org>
I don't know about all the mucky details, but I don't know of any integrated
gui in dos, let alone anything eating up 12M.  I think we'll all agree that
windows eats memory, which is a tradeoff for the gui and other features, but
dos was pretty trimeed down.  Maybe not as powerful or stable as linux, but
I wouldn't call it a memory hog.
Ken
>Shalon Wood
