POV-Ray : Newsgroups : povray.windows : [OT] REQ: command-line ZIP utility Server Time
17 Mar 2026 02:44:38 EDT (-0400)
  [OT] REQ: command-line ZIP utility (Message 1 to 10 of 13)
Subject: [OT] REQ: command-line ZIP utility
Date: 26 May 2003 07:19:28
Message: <3pt3dvgo6f1frsg0a5fj6qq3fgjopo3sm9@4ax.com>
Hi folks,
I'm in the search of a command-line ZIP utility that fulfills the
following requirements:
a) It runs from the command-line under Win9x/ME/2000/XP
b) It ZIPs :) (WinRAR can't zip from the command line)
c) It has no problem with long file names (like PKZIP does)
d) It can take the list of files to archive from a text file (InfoZIP
cannot do that)
e) The license does not prohibit commercial usage or does so at a
registration fee which can be paid online or via bank transfer (I need
it fast, money order or check is not an option)
Any help would be appreciated.
Peter Popov ICQ : 15002700
Subject: Re: [OT] REQ: command-line ZIP utility
Date: 26 May 2003 07:30:57
Message: <0bu3dvgvavmp56gavmshss5ahnjcqmb5qv@4ax.com>
I use set of infozips calls in MegaPOV tool chain for my own archiving purposes.
So perhaps one call for whole list of files you could use other tool to process
input list with filenames to call sequence of infozips (thought I do not know
about licensing issues when redistributed). AFAIK "for" available in dos boxes
can be used for it under some windowses. Here is example how I use it:
DOCRELEASE=www\megapov$(RELEASE)
$(DOCRELEASE)html.zip:\
	$(DOCRELEASE).html\
	$(CSS)
	if exist $@ del $@
	zip -jqr9 $@ $(DOCRELEASE).html
	zip -jqr9 $@ $(CSS)
	zip -jqr9 $@ www\img
	zip -jqr9 $@ www\icons
	zip -jqr9 $@ www\msim_tut
	zip -jqr9 $@ www\*.pov
ABX
Date: 26 May 2003 07:47:00
Message: <ijv3dvsm31dsi7af3mjf964veuqfqj0pnq@4ax.com>
Wouldn't that be kinda slow? I mean, if I have to archive 20 files 5MB
each, every time it will have to process the already created archive,
and I need that for an online operation so it has to be rather fast.
Date: 26 May 2003 08:01:59
Message: <btv3dv0pcah8tjolcct6t0fbb82d1ua1ga@4ax.com>
Depends on system, drive, memory :-)
I just tested and following command works fine:
  infozip.exe arch.zip c:\winnt\NOTEPAD.EXE c:\Borland\Bcc55\Bin\bcc32.exe
so is your list so long that you can't zip it from commandline ? 20 files could
probably fit.
ABX
Date: 26 May 2003 08:48:18
Message: <slrnbd425s.ctj.steev@hot.pl>
Peter Popov donosi :
> Hi folks,
< http://www.7-zip.org/ >
  ________
 \__ \__ \_______________________________________________________________
Date: 26 May 2003 09:44:40
Message: <9f64dvo630v7v02g8fr8iri7lnkj316bkj@4ax.com>
On Mon, 26 May 2003 12:29:48 +0000 (UTC), S?awomir Szczyrba
Slawomir, I already tried 7-zip and unfortunately it can't handle long
file names with spaces in the name/path, and it also proved quite
unstable when archiving large files (100-200 MB). 10x anyway :)
Date: 26 May 2003 11:23:38
Message: <3ed2317a$1@news.povray.org>
Mmmh... Filzip ?
http://www.filzip.com/
Seems to fit the bill, although I did not test command-line.
Peter Popov wrote:
> Hi folks,
> cannot do that)
> Personal e-mail : pet### [at] vipbg
> TAG      e-mail : pet### [at] tagpovrayorg
Date: 26 May 2003 12:02:18
Message: <3ED23A89.EC74E087@gmx.de>
> cannot do that)
With option '-@' Info-ZIP zip can read a list of file names from stdin.
Last updated 28 Feb. 2003 _____./\/^>_*_<^\/\.______
Date: 26 May 2003 12:41:51
Message: <3ed243cf@news.povray.org>
Philippe Debar wrote:
> Mmmh... Filzip ?
Just checked Filzip's doc : there is a switch for loading a filelist
 From the doc :
> If you want to add a big number of files to an archive, write them into
> a textfile, one in each line, use the -s switch and run with this file
> as parameter. Example:
> filzip.exe -a -rps test.zip param.txt
Don't be fooled by the homepage that seems to be dead since mid 2002 (no
news), I just checked and all the stuff is happening in the forums. v2.1
will be skipped and v3 is in private beta.
Philippe
Date: 26 May 2003 13:05:34
Message: <Xns9387852146E31tomatimporg@204.213.191.226>
Peter Popov <pet### [at] vipbg> wrote in news:3pt3dvgo6f1frsg0a5fj6qq3fgjopo3sm9
@4ax.com:
> Hi folks,
You could always roll your own:
perl
Archive::Zip
perl2exe
