POV-Ray : Newsgroups : povray.windows : newbie: lights and cut-outs Server Time
1 Apr 2026 02:22:01 EDT (-0400)
  newbie: lights and cut-outs (Message 1 to 2 of 2)
Subject: newbie: lights and cut-outs
Date: 19 Nov 2003 16:53:55
Message: <3fbbe673@news.povray.org>
I am trying to make a scene with cutouts using csg.
In this example, I've taken two sphere's the smaller subtracted from the
larger to make a sphere with a hole.
If I have a light source outside of this construct, the effects are correct
(this is a glass object).  here is the script:
global_settings {
   photons {
     count 200000
     autostop 0
     jitter .4
     media 100
     max_trace_level 10
#include "textures.inc"
    location <0, 2, -10>
    look_at  <0, 1,  2>
light_source {
  <1,2,-3>
  color White
  photons {
    refraction on
difference {
  sphere {
    <0,1,0>
    1
  sphere {
    <0,1,0>
    .9
  inverse
    pigment { color <1,1,1,.9> }
  interior {
    ior 1.5
  photons {
    target
    refraction on
plane {
  y,-1
  texture { pigment { color White } }
Now if the light is repositioned to <0,1,0> it doesn't seem to produce the
expected result.
There must be a simple solution to this problem.  Can somebody please help
me with it?  Thanks,
Lee
Subject: Re: newbie: lights and cut-outs
Date: 20 Nov 2003 13:15:51
Message: <opryx7otsi0x9foi@news.povray.org>
On Wed, 19 Nov 2003 15:53:51 -0600, Lee Brown
<mr_### [at] acruelandbeautifulworldcouk> wrote:>
> difference {
>   sphere {
>     <0,1,0>
>     1
>   sphere {
>     <0,1,0>
>     .9
>   inverse
What is the inverse doing there? Now you are creating a glass filled scene
with a small spherical shell without glass. As you perhaps notice the
rendering messages warn you of a camera inside a non-hollow object.
> the
> expected result.
I don't know what effect you expect, but that seems to be the right
behavior. (In the center of your "sphere construction" the light won't
bend and focus to a bright area on the ground)
light_source{20*y,1}#macro _(M,X,Y,P)#macro L(N,D)#if(N)#declare
P=P+D;box{-
0.5,0.5translate z*mod(9*P.gray,4)pigment{rgb P}rotate 45*x+clock*y
translate
P}L(N-1,D)#end#end#if(M)L(mod(M,8)<mod(X,3)mod(Y,3)1>-1)_(div(M,8)div(X,3)div
(Y,3)P)#end#end _(2301603551,12850,60365,20*z-5*x)plane{y,-9pigment{rgb 1}}
