POV-Ray : Newsgroups : povray.windows : up-to-date command line version Server Time
4 Sep 2025 00:22:04 EDT (-0400)
  up-to-date command line version (Message 1 to 10 of 23)
Subject: up-to-date command line version
Date: 6 Oct 2003 05:19:55
Message: <3f8133bb$1@news.povray.org>
Dear All,
Is there an up-to-date command line version of POV-Ray available,
(executable for MS Windows)?
The GUI seems to have the queue limited to 300 entries.
I do not want to call the GUI with the command line
parameters for thousands of frames.
Thanks,
Maciej
Subject: Re: up-to-date command line version
Date: 6 Oct 2003 06:12:03
Message: <3f813ff3@news.povray.org>
In article <3f8133bb$1@news.povray.org> , Maciej <wet### [at] pocztaonetpl>
There is no such official version, only unofficial versions, but those are
not compiled with state-of-the-art compilers like the official Windows
version.  But you can call the official Windows version via the command-line
just fine.
If you are rendering an animation, what is preventing you from using "clock"
like everybody else does?
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 6 Oct 2003 06:32:32
Message: <asg2ovk3osu5v791h1po828honh7786orv@4ax.com>
On Mon, 06 Oct 2003 11:23:37 +0200, Maciej <wet### [at] pocztaonetpl> wrote:
> Dear All,
You can call GUI version from command line. In case you do not want splash
screen you can google for QuietPOV.
I do not remember such limitation but who knows...
I do not understand above sentence. In 300 entries do you mean 300 frames of
one animation ? Then you can render it at once as 1 entry using animation
options.
If you see any language problems feel free to ask in Polish in
povray.international using [pl] at subject begining.
Regards, ABX
Date: 6 Oct 2003 06:35:28
Message: <3f814570$1@news.povray.org>
> version.
Where can I get unofficial versions? :-)
AFAIK "clock" is just a variable with subsequent values...
In my case, every frame is quite different and produced
by an external program.
Maciej
ps. I'd call GUI if it only had a switch "do not start GUI" :-)
Date: 6 Oct 2003 06:40:06
Message: <8bh2ov4k550nqbn4eu2jsvibl9vcl7m3cj@4ax.com>
For example: http://megapov.inetart.net/
You can use one file to boundle all 300 frames into one:
//begin file
  #include concat("frame",str(frame_number,0,0),".inc")
//end file
Look into manual for details about your wishes, there is platform dedicated
chapter number one.
ABX
Date: 6 Oct 2003 06:41:49
Message: <3f8146ed@news.povray.org>
I just checked:
1. Windows limits selecting multiple files in the
    "Open" system dialog
2. POV-Ray limits the queue to 512 entries.
Maciej
Date: 6 Oct 2003 06:50:06
Message: <3f8148de@news.povray.org>
"clock"
Not everybody uses clock!
Kitty5 NewMedia http://Kitty5.com
TEL : +44 (01270) 501101 - ICQ : 15776037
PGP Public Key
Date: 6 Oct 2003 07:07:07
Message: <3f814cdb$1@news.povray.org>
> //begin file
> //end file
Yes, that is true, this IS a workaround and it is
different from calling a command-line program
that everybody is used to do :-)
Thanks,
Maciej
Date: 6 Oct 2003 07:22:26
Message: <Xns940C4AC35635Ctomatimporg@204.213.191.226>
ABX <abx### [at] abxartpl> wrote in
news:8bh2ov4k550nqbn4eu2jsvibl9vcl7m3cj@4ax.com:
> dedicated chapter number one.
> ABX
AFAICT, that is not documented or possible.
Tom
The Internet Movie Project
http://www.imp.org/
Date: 6 Oct 2003 07:37:58
Message: <trk2ovg9ck99bgk0ohq8io1mlm7p95k4mm@4ax.com>
Indeed, I see it,
#define MAX_QUEUE       512
in pvguiext.h.
So you can recompile it for your needs with highier MAX_QUEUE setting.
ABX
