POV-Ray : Newsgroups : povray.windows : Command-line only usage for Povray 3.5 for Windows Server Time
21 Jul 2026 16:40:39 EDT (-0400)
  Command-line only usage for Povray 3.5 for Windows (Message 1 to 10 of 11)
Subject: Command-line only usage for Povray 3.5 for Windows
Date: 2 Sep 2002 04:13:17
Message: <3d731d9d@news.povray.org>
Hi All,
Is there any way of using PovRay 3.5 for Windows in a command-line onyl
fashion?
I'm creating sceen files in an automatic manner. As the rending is also
fully automated it would be nice to have an old dos-style command-line only
way to render the image, without having the GUI starting.
Unfortunately the documentation does not specify such an
option for pvengine.
Thanks a lot!
Cheers,
Wolf
Subject: Re: Command-line only usage for Povray 3.5 for Windows
Date: 2 Sep 2002 04:18:35
Message: <qj76nu4h66le1t0mkssppaphvm565t4u31@4ax.com>
On Mon, 2 Sep 2002 10:10:59 +0200, "Wolf" <wmo### [at] webde> wrote:
> Hi All,
> fashion?
"1.9.1  Special Command-Line Options"
ABX
Date: 2 Sep 2002 14:11:17
Message: <3d73a9c5$1@news.povray.org>
"Wolf" <wmo### [at] webde> wrote in message news:3d731d9d@news.povray.org...
> Hi All,
> fashion?
Short answer: No
Long Answer: Due to the abuse of version 3.1 by some unscrupulous companies,
that functionality is no longer availiable.  In order to comply with the new
license, the splash screen must be displayed.
Date: 3 Sep 2002 11:10:13
Message: <web.3d74d00cc8702202b597c920@news.povray.org>
I suppose if you really gotta' have CLI, you could try the DOS version of
3.1g, but it ain't 3.5.... ;-)
Just look for the old versions on the website at the bottom of
http://www.povray.org/download/
--Mark W.
Tom Galvin wrote:
>"Wolf" <wmo### [at] webde> wrote in message news:3d731d9d[at]news.povray.org...
>> Hi All,
>> fashion?
>Short answer: No
Feel the power of the penguin at www.libranet.com
Date: 7 Sep 2002 07:54:59
Message: <B99FA6D3.4541%fidel.viegas@artrecognition.co.uk>
I think there is a version of povray 3.5 for cygwin somewhere on the web. I
don't really remember where I saw it, but you could try the povray.unix
newsgroup.
Best Regards
Fidel.
in article web.3d74d00cc8702202b597c920@news.povray.org, LibraryMan at
mrm### [at] attnet wrote on 3/9/02 4:06 pm:
> --Mark W.
>>> Hi All,
>>> fashion?
>> Short answer: No
Date: 7 Sep 2002 08:13:14
Message: <3D79ED58.D85376AE@gmx.de>
> newsgroup.
No, POV-Ray 3.5 does not seem to compile correctly without the unix
emulation DLL from cygwin (it compiles, but the resulting binary isn't
functional). A program linked with that library requires to be under open
source licence for distribution.  You can compile POV-Ray 3.5 fairly
straight away with cygwin, but you probably won't find a compiled binary
for distribution.
Date: 7 Sep 2002 11:39:42
Message: <3d7a1dbe$1@news.povray.org>
In article <3D79ED58.D85376AE@gmx.de> , Christoph Hormann
Well, why would you use the Unix source code as is?  Just remove unix.cpp
and change config.h to no longer depend on it.  Then it will work just fine!
    Thorsten
e-mail: tho### [at] trfde
Date: 7 Sep 2002 11:43:36
Message: <3D7A1EA8.7E56CF6A@gmx.de>
No, that's not the problem.
Date: 7 Sep 2002 16:16:55
Message: <3d7a5eb7@news.povray.org>
In article <3D7A1EA8.7E56CF6A@gmx.de> , Christoph Hormann
So what is?  There should be no need to emulate any Unix functions (except
getcwd, which can be defined out of existence with a few restrictions),
so...
    Thorsten
PS: In case you saw the reply I just canceled, that was meant for another
group and I types in the wrong window...
Date: 7 Sep 2002 16:18:39
Message: <3d7a5f1f@news.povray.org>
In article <qj76nu4h66le1t0mkssppaphvm565t4u31@4ax.com> , ABX
<abx### [at] abxartpl>  wrote:
>> Hi All,
>> fashion?
And make sure to read:
Date: Thu, 15 Aug 2002 13:19:24 +0200
Newsgroups: povray.windows
Subject: Re: NO whitespaces allowed in Path to ini ?
Message-ID: <3d5b8e3f$1@news.povray.org>
Xref: news.povray.org povray.windows:4737
