POV-Ray : Newsgroups : povray.windows : NO whitespaces allowed in Path to ini ? Server Time
31 May 2026 20:16:53 EDT (-0400)
  NO whitespaces allowed in Path to ini ? (Message 1 to 10 of 39)
Subject: NO whitespaces allowed in Path to ini ?
Date: 13 Aug 2002 11:32:56
Message: <3d5926a8@news.povray.org>
The following Line in a batch file:
bin\pvengine.exe "f:\00_rpgm\01_bs\01_projekte\smpov
1\com\ani_woodbox_08132002_172415_87176_1_0x0-160x120a.ini"
Please note the chr$(34) (=") around the path.
Gives the following error (below).
Seems that POV does not allow pathes with whitespaces at all outside of
".ini"-Files ?
If that is the case what do I do if the ".ini" File is somewhere where there
are whitespaces in
the file-path ?
If that behavior is wanted, it would be good to know.
thanks
--Theo
PS: :
This Windows version by Christopher J. Cason
Possible Command Line Error: Could not open INI file
'f:\00_rpgm\01_bs\01_projekte\smpov'.
'1\com\ani_woodbox_08132002_172415_87176_1_0x0-160x120a.ini""'.
Parsing Options
Returned from renderer with error status
Subject: Re: NO whitespaces allowed in Path to ini ?
Date: 13 Aug 2002 11:36:45
Message: <vo9iluktdb0a3th9s7pqmpqr99g98mgbsd@4ax.com>
On Tue, 13 Aug 2002 17:33:17 +0200, "Theo Gottwald *"
only in batch file ?
I don't know but you can always try short names equivalent.
ABX
Date: 13 Aug 2002 11:50:54
Message: <3d592ade@news.povray.org>
Hmmm ... to change all pathes to "short-name equivalent" first.
It could be a sollution if we would know that the resulting file would
always run on THAT particular computer. Which is infact NOT the case here
Hmmm. If there is no sollution to give the full path to POV, I guess I have
to restrict the proggy to a "non whitespace path".
thanks
--Theo
"ABX" <abx### [at] babilonorg> schrieb im Newsbeitrag
news:vo9iluktdb0a3th9s7pqmpqr99g98mgbsd@4ax.com...
> ABX
Date: 13 Aug 2002 11:59:34
Message: <t2biluk6a6ijm0onqr5r9q3eci07eribo4@4ax.com>
On Tue, 13 Aug 2002 17:51:15 +0200, "Theo Gottwald *"
I have just tested as
  pvengin.exe "abx test.ini"
and it worked fine. No idea what could be wrong in your situation.
ABX
Date: 13 Aug 2002 12:53:16
Message: <3d59397c$1@news.povray.org>
Sounds intresting to me. I have win2k. My POV does as if the """ would not
be there.
Do you have W2k or ... ?
--Theo
news:t2biluk6a6ijm0onqr5r9q3eci07eribo4@4ax.com...
have
> ABX
Date: 13 Aug 2002 12:58:26
Message: <3d593ab2$1@news.povray.org>
In article <3d5926a8@news.povray.org> , "Theo Gottwald *"
> ".ini"-Files ?
It is not POV-Ray's problem but that of your shell.  It separates the path
into two separate arguments.  Read up in your shell documentation how to
specify special characters in command lines.
    Thorsten
Date: 13 Aug 2002 13:00:55
Message: <hmeiluorohub0t7mthrscqj9inohdst3ce@4ax.com>
On Tue, 13 Aug 2002 18:53:37 +0200, "Theo Gottwald *"
> I have win2k.
NT4 Sp6 here.
ABX
Date: 13 Aug 2002 14:14:31
Message: <3d594c87@news.povray.org>
Good to know. My shell is the CMD.exe from W2k.
However, 'll take that problem for Version 2 ...
thanks for trying
-Theo
"Thorsten Froehlich" <tho### [at] trfde> schrieb im Newsbeitrag
news:3d593ab2$1@news.povray.org...
> > ".ini"-Files ?
>     Thorsten
Date: 14 Aug 2002 11:12:23
Message: <3d5a7357@news.povray.org>
Try putting the parameter into quotation marks.
Date: 14 Aug 2002 11:37:33
Message: <3d5a793d$1@news.povray.org>
I did that, they have been in Quotation marks (=chr$(34) - isn't ?).
"Warp" <war### [at] tagpovrayorg> schrieb im Newsbeitrag
news:3d5a7357@news.povray.org...
x]
Warp -
