POV-Ray : Newsgroups : povray.windows : File queues & ini files Server Time
17 Mar 2026 04:23:28 EDT (-0400)
  File queues & ini files (Message 1 to 6 of 6)
Subject: File queues & ini files
Date: 10 Jun 2002 04:03:56
Message: <3d045d6c@news.povray.org>
Hi
It would useful to associate a particular ini file to a particular pov file.
I wish to render a batch of files, using file queue, but they each have
their own ini file stting frame nos. etc. Any ideas?
Chris in Isle of Man
Subject: Re: File queues & ini files
Date: 10 Jun 2002 04:11:46
Message: <kgn8gu4a74e08gbpt18knmgcb0siro2s5t@4ax.com>
On Mon, 10 Jun 2002 09:03:59 +0100, "Chris Baker" <chr### [at] mdiomcoim> wrote:
> Hi
I don't understand your problem - ini files are already "associated" to pov
files with Input_File_Name option (equivalent of +I switch). And You can
render queue of ini/pov files with Queue function. So what's the problem you
have exactly?
ABX
Date: 10 Jun 2002 05:45:08
Message: <3d047524@news.povray.org>
news:kgn8gu4a74e08gbpt18knmgcb0siro2s5t@4ax.com...
file.
pov
you
> have exactly?
That was probably it, maybe just needed to know to queue the INI's instead
with a Input_File_Name=scene.pov added to each. I would guess opposite to
the common way most people render a file, ie. pov with associated ini versus
ini with associated pov.
bob h
Date: 15 Jun 2002 05:47:24
Message: <3d0b0d2c$1@news.povray.org>
Does anyone know how to increase the size of the file que or run mulitple
scene files from a ini file?  I'm developing a program that outputs many
frames (1500+) and I have to launch mulitiple instances to run all of the
scene at once.
-Zach
"bob h" <omn### [at] charternet> wrote in message
news:3d047524@news.povray.org...
> file.
have
> pov
> you
> > have exactly?
versus
> bob h
Date: 15 Jun 2002 09:39:20
Message: <0R8W5CA$4zC9EwqM@econym.demon.co.uk>
>scene at once.
Can you possibly use techniques designed for animation?
Group together the scenes that have the same basic ini file requirements
and give them names that can be calculated programmatically (e.g.
scene1.pov, scene2.pov etc.). Then the associated ini file invokes a
master POV scene file with a suitable final_frame setting. The
Master.pov file looks at the current frame number, determines the name
of the next actual POV scene file and #include's it.
Mike Williams
Gentleman of Leisure
Date: 13 Jul 2002 05:04:50
Message: <3d2fed32$1@news.povray.org>
Could you script such an example?
Thanx
-Zach
"Mike Williams" <mik### [at] econymdemoncouk> wrote in message
news:0R8W5CA$4zC9EwqM@econym.demon.co.uk...
> >scene at once.
> Mike Williams
