POV-Ray : Newsgroups : povray.windows : Subsections Server Time
5 Feb 2026 19:12:21 EST (-0500)
  Subsections (Message 1 to 8 of 8)
Subject: Subsections
Date: 8 Nov 2000 01:54:09
Message: <3a08f891@news.povray.org>
How do I render a subsection of an image so that the resulting image is of
the size of that subsection (not the size of the full image)?
I'm aware of Start_Row, Start_Column, End_Row and End_Column, however the
resulting image size (from using just these options) is that of the full
image instead of just the subsection.
Ouroborus
Subject: Re: Subsections
Date: 8 Nov 2000 02:27:12
Message: <3A0900AB.291809CE@pacbell.net>
> Ouroborus
In the windows version of the program is a rubberband feature.
Start a render. When the render window appears stop the render
by pressing alt g. Use your mouse to define the area you wish
to render. A dialog will popup after you define the area asking
if you want to render that area now. Choose yes. It will only
render the selected area you choose.
Date: 8 Nov 2000 04:54:25
Message: <3A0922D0.D16C83BB@schunter.etc.tu-bs.de>
I think that does exactly the same as Start_Row etc. do.  To render an area in
full width and height you either have to change the camera or calculate the
larger full size necessary to get the subsection in the size wanted.
Date: 8 Nov 2000 04:59:16
Message: <3a0923f4@news.povray.org>
"Ken" <tyl### [at] pacbellnet> wrote in message
news:3A0900AB.291809CE@pacbell.net...
Going out on a short limb here, I think Ouroborus doesn't want the entire
window size for the specified render resolution to show but to only have a
render window the size of the selected region instead.  Must need work space
while viewing I guess.
Can't be done.  Although the window size and view position can be manipulated
in the usual way.  I'm also talking about the Windows OS here.
In fact, you may have come across a good feature idea Ouroborus.  Either to
have a Window menu like some other programs do (set Window size and/or position
then remember it) or a region-only window.
Date: 8 Nov 2000 13:26:26
Message: <3a099ad2$1@news.povray.org>
"Bob H."
<per### [at] aolcom?subject=PoV-News:%20&body=Relating%20to%20POV-Ray:>
wrote in message news:3a0923f4@news.povray.org...
the
full
space
manipulated
to
position
Yes, you explain much better what I was trying to accomplish.
The reason is different though. The image I'm rendering is 8868x22131 and as
a uncompressed BMP comes to over 600 meg. It turns out that a lot of
graphics editors can even load an image of this size. (I did find one that
can view it called 'ER Viewer' at www.ermapper.com).
My goal is to either render it in pieces or slice up a complete rendering.
So, alternatively, can anyone suggest some graphics slicing software that
can handle huge files?
My thanks,
Ouroborus
Date: 8 Nov 2000 14:17:51
Message: <3A09A6DF.3C87A573@schunter.etc.tu-bs.de>
If you can cope with horizontal stripes, just use +SR and +ER to render those
stripes.  I don't know what you want to do with the file, so it's not easy to
suggest a solution.
Date: 9 Nov 2000 00:49:36
Message: <3a0a3af0$1@news.povray.org>
Ouroborus wrote in message <3a099ad2$1@news.povray.org>...
as
If you output it as a series of uncompressed TARGA images (+FT), it is easy
enough to write a program to put the pieces together.
Mark
Date: 19 Dec 2000 08:51:06
Message: <3a3f67ca$1@news.povray.org>
"Ouroborus" <our### [at] hotmailcom> wrote in message
news:3a099ad2$1@news.povray.org...
Well, if you can view it, PSP (and many other progs) would allow you to
capture an area.
