POV-Ray : Newsgroups : povray.windows : Local Transformations Server Time
12 Jun 2026 17:11:30 EDT (-0400)
  Local Transformations (Message 1 to 10 of 21)
Subject: Local Transformations
Date: 6 Jan 1999 19:48:59
Message: <36940628.ABB48441@emc-inc.com>
Is there any way to do local transformations based on an object's
current scale, position & rotation?  (i.e. a translation on an object's
X axis as apposed to the origin's X axis)
If there isn't currently a way to do this, is there enough interest for
someone to create a patch?
Subject: Re: Local Transformations
Date: 6 Jan 1999 23:22:53
Message: <36963665.129679744@news.povray.org>
On Wed, 06 Jan 1999 16:56:08 -0800, Tony Vigil <tvi### [at] emc-inccom>
Maybe I'm an idiot, but if you can't just put the translate along the
X axis in before whatever transformation moved it to the new position,
how is the software going to know what you thought the X axis was?
Date: 7 Jan 1999 01:35:16
Message: <369455AE.B8977B3B@aol.com>
You're hardly an idiot.
=Bob
Download 'us-ascii' (1 KB)
Date: 7 Jan 1999 14:54:46
Message: <369512B3.B9F1079D@emc-inc.com>
Maybe I am missing something.
If you have an object that is positioned at <0,0,0> and is rotated 45 degrees
on the Y axis, then translate it 1 unit on the X axis, won't it be located at
<1,0,0>???
What I was wanting to do is translate that same object (with it's rotated
axis), 1 unit on it's own X axis.
The approximate coordinates would become < 0.71, 0,  0.71> instead of <1,0,0>
>   http://members.aol.com/inversez/POVring.htm
> =Bob
Download 'us-ascii' (2 KB)
Date: 7 Jan 1999 14:56:00
Message: <36951301.61FF93C8@emc-inc.com>
If VRML can do it, why not POV???
Date: 7 Jan 1999 15:43:39
Message: <36951c7b.0@news.povray.org>
In article <369512B3.B9F1079D@emc-inc.com> , Tony Vigil <tvi### [at] emc-inccom>  wrote:
No, you aren't missing something, you just did not read the docs! See section
4.3.1.3.
><1,0,0>???
So your code would look like:
rotate <0,45,0>
translate <1,0,0>
Did you consider (after reading the docs) to write:
translate <1,0,0>
rotate <0,45,0>
It will do what you want - and reading the docs will surely show you some other
features you don't even know about! :-)
    Thorsten
Date: 7 Jan 1999 15:50:14
Message: <36951e06.0@news.povray.org>
On Thu, 07 Jan 1999 12:01:55 -0800, Tony Vigil <tvi### [at] emc-inccom> wrote:
In that case, please allow me to elucidate.
><1,0,0>???
Yes it will.  That's not what I was trying to say.
All you have to do is translate first, then rotate:
    sphere {
      0, 1
      /* local transformations */
      translate x
      /* global transformations */
      rotate 45*y
makes a sphere with its center at <sqrt(.5),0,sqrt(.5)>, just as requested.
This works for more complex objects and transformations, too, but the proof
is left as an exercise for the reader. (See Exercise 2.)
This assumes you're actually doing the rotation, of course.  If you're not,
(for example, you're using a mesh exported from Poser) then there's no way
for you or POV to know what "its own X axis" is.  If you're not doing the
rotation, but you know something about the rotation and can supply the
necessary parameters in the form of a rotation vector, then what you need
to do is:
    #macro InvRotate( Rot )
      transform {
        rotate -Rot.z*z
        rotate -Rot.y*y
        rotate -Rot.x*x
    object {
      MyObject
      #declare Rot=<whatever your rotation vector is>;
      InvRotate( Rot )
      translate x
      rotate Rot
(Note the three rotates to form the inverse: this is because POV always
rotates along X first, then Y, then Z.  The inverse should go in the
opposite direction.)
The same goes for any other transformation: if it's one you did yourself, just
do the "local" transformations first, before you apply the "global" ones.  If
it's not, you have to "back out" the pre-applied "global" transformations,
then apply the "local" ones, then apply the "global" ones again.  I am
hard-pressed to think of a specification syntax that would make this much
easier than it already is.
EXERCISES:
1. Discover a method to turn off the HTML "feature" in your news posting
   software.  Use it.
2. Prove that the method given works for more complex objects and transforms.
3. (Extra Credit) Write a short paragraph on the properties of a trivial
   bijective mapping between the sets (she's, he's, it's) and (her, his, its)
4. (Extra Credit) The First Law of Usenet claims that every spelling flame
   will contain at least one misspelled word or factual error.  Find one in
   this post.
Date: 7 Jan 1999 18:24:14
Message: <369543CF.A44A2BFF@emc-inc.com>
> 4.3.1.3.
I sure did read them.  You have misread them.  Rotations are relative to the object
axis
& translations/scaling are relative to the origin.
> ><1,0,0>???
> rotate <0,45,0>
> translate <1,0,0>
Your code places the object at <1,0,0>.  If POV did have a local coordinate system for
each object, those same transformations would put it at < 0.71, 0,  -0.71>.
> translate <1,0,0>
> rotate <0,45,0>
I sure did.  Now suppose you want to perform another set of transfomations to the same
object:
-45 degrees on the object's Y axis (no translations occuring), then translate 1 unit
along the object's Z axis.  Now what???  The object should be at in it's original
rotational state of <0,0,0> located at <0.71 , 0 , 0.29> - but it's not.
>     Thorsten
Thanks for the reading tip though.  Perhaps you should do likewise. :-)
Tony
Date: 7 Jan 1999 18:34:58
Message: <36954651.8533734C@emc-inc.com>
Thank you mucho for your macro.
Hypothetically, what if you needed to do the following:
Create an object at <0,0,0>
Rotate the object 45 degrees * around the object's Y axis
Translate the object 1 unit along object's X axis (now at a 45 degree angle)
Rotate the object -90 degrees * around the object's Y axis
Translate the object 1 unit along the object's Z axis (now at a -45 degree angle)
Will your macro place the object at <0,0,0> with 0 rotation on each axis?
Mucho thanks!
Tony
> ><1,0,0>???
>     sphere {
>       0, 1
>       translate x
>       rotate 45*y
> to do is:
>       transform {
>         rotate -Rot.z*z
>         rotate -Rot.y*y
>         rotate -Rot.x*x
>     #end
>     object {
>       MyObject
>       InvRotate( Rot )
>       translate x
>       rotate Rot
> EXERCISES:
>    software.  Use it.
>    this post.
Date: 7 Jan 1999 19:15:13
Message: <36954e11.0@news.povray.org>
What you need to do is FIRST translate the object so its position
becomes <1,0,0> and THEN rotate it around the y-axis. (Of course you can
also first rotate and then translate the object using
translate <translation along 'own x-axis'*cos(radians(rotation around
y)),0,translation sin(radians(rotation around y))> (which for 45 deg
would come to <0.71,0,0.71>) but that's a little more complicated.
Julius
http://surf.to/jkhome
United Artists Galleries: http://surf.to/uagalleries
45 degrees on the Y axis, then translate it 1 unit on the X axis, won't
it be located at <1,0,0>???
rotated axis), 1 unit on it's own X axis.
of <1,0,0>
object's
an object's
interest for
along the
position,
was?
        =Bob
Download 'iso-8859-1' (3 KB)
