POV-Ray : Newsgroups : povray.unofficial.patches : problem about MegaPov Server Time
21 Jan 2026 02:22:20 EST (-0500)
  problem about MegaPov (Message 1 to 7 of 7)
Subject: problem about MegaPov
Date: 25 Aug 2014 03:10:01
Message: <web.53fae1032d30c796a92a3a00@news.povray.org>
Recently,I am interested in generating ancillary image planes with MegaPov.Such
as follows:
version 1.2.1 on line 360 must be commented out, otherwise the files which have
MegaPOV version 1.2.1 and pov-ray 3.6.I want to know how can I get ancillary
somebody tell me how can I do? Thanks and expecting reply! Best wishes!
Subject: Re: problem about MegaPov
Date: 25 Aug 2014 13:45:43
Message: <53fb7647@news.povray.org>
> as follows:
postproc.cpp is NOT a programm but a C++ source file.
To do what you want, you need to get the source files, edit the line
360, and compile the executable.
You'll obviously need to get a C++ compiler with all the needed libraries.
Date: 25 Aug 2014 13:49:06
Message: <53fb7712$1@news.povray.org>
> as follows:
> • Colors (Red, Green, Blue and Alpha).
> • The intersection point I(x,y,z) in x(ix,iy), y(ix,iy) and z(ix,iy).
> • Surface normals n(ix,iy) at the intersection point.
> • Distance d(ix,iy) between camera and intersection point.
> An article says:“Note that in order for the image planes to be available to the
> user, a statement to delete the files in the program“postproc.cpp” for MegaPOV
> the extension PPD are deleted after the rendering is completed.” I have set up
> image planes with MegaPov. I did not find the program “postproc.cpp”.Can
You need the sources of megapov 1.2.1 (
> http://megapov.inetart.net/packages/unix/megapov-1.2.1.tar.bz2
Then the file is ./source/patches/postproc.cpp
Once changed, you "just" have to compile your version of megapov.
IQ of crossposters with FU: 100 / (number of groups)
IQ of crossposters without FU: 100 / (1 + number of groups)
IQ of multiposters: 100 / ( (number of groups) * (number of groups))
Date: 26 Aug 2014 00:55:01
Message: <web.53fc13158f4a2ad86a92a3a00@news.povray.org>
> > as follows:
360,but there are many problems when I compiled.I have a beg,could you please
give me a compiled MegaPOV-1.2.1-windows.zip which have commented out the line
360.I need to set up modified MegaPOV-1.2.1-windows currently.Sorry to bring you
so much teouble!Thank you and expecting your reply! Best wishes!
Date: 26 Aug 2014 12:51:32
Message: <53fcbb14@news.povray.org>
On 26/08/2014 06:54, CAS wrote:
> Thank you for your help.I have found“postproc.cpp”and commented out the line
Well, sorry but I have no windows system to generate such binary.
Maybe someone else can help ?
Date: 27 Aug 2014 11:45:00
Message: <web.53fdfc098f4a2ad86a92a3a00@news.povray.org>
Anyway,I am very grateful to you.I have solved this problem.However,I
encountered a new problem.I need to generate ancillary image planes with
MegaPov.Such as:
I found that the output rendered by MegaPov is the same as POV,that means no
difference with POV. How can I make MegaPov output auxiliary images such as
above I listed? Beg a hot!Thanks and expecting reply! Best wishes!
Date: 28 Aug 2014 02:29:14
Message: <53fecc3a$1@news.povray.org>
the line
> MegaPov.Such as:
It seems to be in the doc:
http://megapov.inetart.net/manual-1.2.1/megapov0121.html#post_processing
Read it carefully and slowly. (hint: global_settings)
Just because nobody complains does not mean all parachutes are perfect.
