POV-Ray : Newsgroups : povray.unofficial.patches : Error in Mechsim Tutorial Server Time
29 May 2024 05:22:55 EDT (-0400)
  Error in Mechsim Tutorial (Message 1 to 4 of 4)
Subject: Error in Mechsim Tutorial
Date: 24 Jun 2005 15:25:00
Message: <web.42bc5a03c22a8d403948f8f0@news.povray.org>
All Tutorials (2 through 9)from the mechsim tutorial in the 1.2
documentation generates this error on my system when run
---START SNIPPET---
  File: C:ArtPOV-Ray for Windows v3.6INCLUDEmechsim.inc  Line: 14
  File Context (5 lines):
  // -w320 -h240 +a0.3 -j +kff100
  #version unofficial megapov 1.2;
  #include "mechsim
  Parse Error: Too many nested include files.
---FINISH SNIPPET---
My system is as a Windows XP (Sp2) running on an IBM IntelliStation M Pro (3
GHz processor, 1GB Ram).
I have re-installed everything (POVRay 3.6.1, MegaPOV, fixit DLLs for WinPov
GUI) from scratch.
Any ideas?
Subject: Re: Error in Mechsim Tutorial
Date: 24 Jun 2005 15:55:01
Message: <d9hoas$db5$1@chho.imagico.de>
> ---START SNIPPET---
>   #include "mechsim
You are seemingly doing something very wrong - that code snippet is not
from mechsim.inc so you seem to have renamed a file to 'mechsim.inc' -
this probably results in recursive inclusion.
Replace this wrong mechsim.inc file with the one from the MegaPOV
distribution and it will probably work.
Last updated 03 May. 2005 _____./\/^>_*_<^\/\.______
Date: 27 Jun 2005 15:15:01
Message: <web.42c0500738b707bc3948f8f0@news.povray.org>
> > ---START SNIPPET---
> >   #include "mechsim
> Christoph
> POV-Ray tutorials, include files, Sim-POV,
> HCR-Edit and more: http://www.tu-bs.de/~y0013390/
> Last updated 03 May. 2005 _____.//^>_*_<^/.______
I uninstalled PovRay and made sure to delete the entire install directory.
I then re-installed POVRay 3.6.1a and MegaPov 1.2 beta.  I also downloaded
the latest version of IsoCSG (0.7) and referenced it with a Library_Path
entry in the master POVRAY.INI
Now the tutorials (5 and 6, didn't check the others) fail with the following
error:
---START SNIPPET---
Saved simulation data to file tut05.dat
Generating Objects...Done
File: C:artPOV-Ray for Windows v3.6INCLUDEmechsim.inc  Line: 577
  #fclose FILE
 #debug "Donen
Parse Error: Expected 'object', } found instead
This appears to be related to the line
  MechSim_Show_All_Objects(-1, true, -1, "")
Date: 27 Jun 2005 16:25:02
Message: <d9pn6m$kuu$1@chho.imagico.de>
> error:
> ---START SNIPPET---
>   #fclose FILE
>  #end
>  #debug "Donen
That's a completely different error but i still can't reproduce it.
