![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
All Tutorials (2 through 9)from the mechsim tutorial in the 1.2
documentation generates this error on my system when run
---START SNIPPET---
File: C:ArtPOV-Ray for Windows v3.6INCLUDEmechsim.inc Line: 14
File Context (5 lines):
// -w320 -h240 +a0.3 -j +kff100
#version unofficial megapov 1.2;
#include "mechsim
Parse Error: Too many nested include files.
---FINISH SNIPPET---
My system is as a Windows XP (Sp2) running on an IBM IntelliStation M Pro (3
GHz processor, 1GB Ram).
I have re-installed everything (POVRay 3.6.1, MegaPOV, fixit DLLs for WinPov
GUI) from scratch.
Any ideas?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> ---START SNIPPET---
> #include "mechsim
You are seemingly doing something very wrong - that code snippet is not
from mechsim.inc so you seem to have renamed a file to 'mechsim.inc' -
this probably results in recursive inclusion.
Replace this wrong mechsim.inc file with the one from the MegaPOV
distribution and it will probably work.
Last updated 03 May. 2005 _____./\/^>_*_<^\/\.______
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> > ---START SNIPPET---
> > #include "mechsim
> Christoph
> POV-Ray tutorials, include files, Sim-POV,
> HCR-Edit and more: http://www.tu-bs.de/~y0013390/
> Last updated 03 May. 2005 _____.//^>_*_<^/.______
I uninstalled PovRay and made sure to delete the entire install directory.
I then re-installed POVRay 3.6.1a and MegaPov 1.2 beta. I also downloaded
the latest version of IsoCSG (0.7) and referenced it with a Library_Path
entry in the master POVRAY.INI
Now the tutorials (5 and 6, didn't check the others) fail with the following
error:
---START SNIPPET---
Saved simulation data to file tut05.dat
Generating Objects...Done
File: C:artPOV-Ray for Windows v3.6INCLUDEmechsim.inc Line: 577
#fclose FILE
#debug "Donen
Parse Error: Expected 'object', } found instead
This appears to be related to the line
MechSim_Show_All_Objects(-1, true, -1, "")
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> error:
> ---START SNIPPET---
> #fclose FILE
> #end
> #debug "Donen
That's a completely different error but i still can't reproduce it.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
