POV-Ray : Newsgroups : povray.unofficial.patches : BSP tree bounding patch Server Time
16 Apr 2026 07:30:15 EDT (-0400)
  BSP tree bounding patch (Message 11 to 20 of 26)
<<< Previous 10 Messages Goto Latest 10 Messages Next 6 Messages >>>
Subject: Re: BSP tree bounding patch
Date: 27 Nov 2003 22:15:02
Message: <web.3fc6bd866b3b1e2c611ee4e60@news.povray.org>
ABX wrote:
>On Thu, 27 Nov 2003 09:03:46 EST, "Andrew Clinton" <ajc### [at] uwaterlooca>
>wrote:
>> One exception is that there is a bug fix in TEST_RAY_FLAGS_SHADOW()
>Can you elaborate on this ? Your version is different that current
>development. Any reasons to follow you ? Minimal scene and settings to verify
>why you modified it that way ?
>TIA, ABX
OK.  The problem I was trying to solve can be observed when you render
"advanced/glasschess/glasschess.pov" with and then without the light buffer
turned on (-UL).  The number of shadow ray tests when this scene is
rendered without the light buffer is about 3x the number when it is
rendered with the light buffer.  This is not a side-effect of just not
using the light buffer, because the light buffer should not reduce the
total number of shadow ray tests at all as far as I know.
What I figured to be the problem was that objects in this scene marked with
"no_shadow" were still being tested against by shadow rays when the light
buffer is not used.  When the light buffer is used, this problem is not
noticed because the objects with "no_shadow" are not even put into the
light buffer when it is constructed.
My solution was to change the routine TEST_RAY_FLAGS_SHADOW from
#define TEST_RAY_FLAGS_SHADOW(obj) \
(  (!backtraceFlag && \
(!Test_Flag((obj), NO_IMAGE_FLAG) || In_Reflection_Ray == true) && \
(!Test_Flag((obj), NO_REFLECTION_FLAG) || In_Reflection_Ray == false)) \
||(shadow_flag && !Test_Flag((obj), NO_SHADOW_FLAG)) \
|| (backtraceFlag && !Test_Flag((obj), NO_SHADOW_FLAG)) )
-------- to
(!Test_Flag((obj), NO_REFLECTION_FLAG) || In_Reflection_Ray == false) && \
(!shadow_flag || !Test_Flag((obj), NO_SHADOW_FLAG))) \
|| (backtraceFlag && (!Test_Flag((obj), NO_SHADOW_FLAG) ) ))
This change makes sure that when we are in a shadow ray, and the object
being tested has "no_shadow", we will not test the object.  I also assume
that shadow_flag will never be set during backtrace (reasonable?)
I've just been testing this some more, and realise that this solution is
still not complete.  By fixing this, another bug seems to be exposed where
uninitialized memory is accessed by csg.cpp and isosurface.cpp.  Try
searching for "Optimisiation_Flags" and you will find that this member of
RAY is never initialized for non-shadow rays so its value could be
unpredictable.  This is causing rendering problems for glasschess.pov when
my fix to TEST_RAY_FLAGS_SHADOW is used.
I hope this helps!
Andrew
Date: 27 Nov 2003 22:25:01
Message: <web.3fc6bf9b6b3b1e2c611ee4e60@news.povray.org>
Christoph Hormann wrote:
>I had a closer look at your changes and don't really understand the
>meaning of 'Local_BBox'.
Local_BBox is the bounding box of an object before a transformation.  The
way that POV-Ray currently produces bounding boxes for transformed objects
is to take the 8 vertices of the untransformed box, transform them, then
find the axis-aligned box that contains all the transformed vertices.  This
can produce a lot of slack space around the object, which you can see by
imagining to transform a long thin cylinder by 45 degrees.
I've added the abilitly to store the bounding box of the object before it
has been transformed.  This allows the tree construction to take advantage
of some more detailed information about the objects in the scene which can
produce a better tree.  For now, I am only using the local box to determine
whether the object should be a member of a cell in the tree - by using a
box/box intersection algorithm.
>BTW the way you implemented the additional statistics is of course not
>the right way(tm) but i'd suggest you wait until the next official
>version before changing this because otherwise you will have to modify
>it twice.
How do I implement the statistics in the right way?
Andrew
Date: 27 Nov 2003 22:30:00
Message: <web.3fc6c0dc6b3b1e2c611ee4e60@news.povray.org>
George Pantazopoulos wrote:
>Andrew, I can't try out your patch because Im getting all kinds of make
>errors after applying your diffs (exactly as shown in your README). Could
>you please post the actual source files?
>Thanks,
>George
What kind of make errors are you getting?  Maybe I should be compiling with
stricter settings, unless the problem is with the diffs and not the source.
 I have been using gcc 3.2.1 to compile.
Andrew
Date: 27 Nov 2003 22:42:32
Message: <oprzbwo1b0u942mt@news.povray.org>
First of all, when I do "patch -p2 <bsppov.diff" in the src/ directory:
after it gets to "patching file optout.h" it says:
"Hunk #1 FAILED at 46"
Next it says:
"the next patch would create the file stamp-h, which already exists. Assume
-R" ?
I'm not sure what to enter there, either. I've tried it both ways and I
haven't gotten anywhere.
Beyond that, after ./configure and during the subsequent make, it would
tell me that
"your implementation of AM_INIT_AUTOMAKE comes from an older version of
automake" and to run aclocal
I tried that, but then after making I get tons of errors of the type:
"torus.Po: no such file/directory"
George
On Thu, 27 Nov 2003 22:28:28 EST, Andrew Clinton <ajc### [at] uwaterlooca>
>> Could
>> Thanks,
>> George
> with
> source.
> Andrew
Using M2, Opera's revolutionary e-mail client: http://www.opera.com/m2/
Date: 27 Nov 2003 22:43:42
Message: <oprzbwqxxpu942mt@news.povray.org>
I neglected to mention that I'm on redhat 9, with gcc 3.3.1
> Next it says:
> Assume -R" ?
> tell me that
> George
>>> Could
>>> Thanks,
>>> George
>> with
>> source.
>> Andrew
Date: 27 Nov 2003 23:20:01
Message: <web.3fc6cbfd6b3b1e2c611ee4e60@news.povray.org>
Can you try installing the full set of modified files:
http://povplace.addr.com/bsppov-src.tar.gz
and let me know if you still have problems compiling?  Make sure that you
start with a completely fresh povray-3.50c.
Andrew
Date: 27 Nov 2003 23:34:45
Message: <oprzby3yfhu942mt@news.povray.org>
Thanks Andrew.
I made a fresh povray-3.50c-bsp/ directory and copied your src/ into
povray-3.50c-bsp/src
However, after ./configure the make failed with the same error as before:
After running aclocal and trying again I still got that whole bunch of
errors where it cant find some mysterious ".Po" files (not a typo). That's
from the Makefile within povray-3.50-bsp/src/ lines 256 thru 352.
Doing "make --version" shows GNU make 3.79.1
Anything else you need to know?
Thanks,
George
> Andrew
Date: 28 Nov 2003 00:20:01
Message: <web.3fc6d9e36b3b1e2c611ee4e60@news.povray.org>
>Thanks,
>George
Can you successfully build povray before overwriting with patched files?
This should at least make sure you have a working automake... If you can't
build the source without the patched files you probably won't be able to
build it with the patch.
Andrew
Date: 28 Nov 2003 00:24:59
Message: <oprzb1fme1u942mt@news.povray.org>
I can indeed build povray-3.50c, Andrew.
	I just tried copying all the modified source files, but not any of the
Makefiles, and I came very close to compiling it.. but it errored out with
"undefined reference to Instersect_Bsp_Tree()" and several other BSP
related errors like that.
Besides adding bsptree.cpp to the list of source files in the Makefile,
what else would I have to add to it?
Thanks,
George
> can't
> Andrew
Date: 28 Nov 2003 18:01:14
Message: <3fc7d3ba$1@news.povray.org>
Hello again,
I've compiled a version of povray3.5c with bsp-tree patch on a Fedora 1
linux (gcc 3.3.2, and only added -mcpu=athlon-xp to the options). Tested
with benchmark.pov. Not much differences in rendering time (slighty faster
with BSP tree) but there is a change in the image , a small part at the
left-bottom of the checkered vase have disappeared in the povray-bsp version
M
