POV-Ray : Newsgroups : povray.unofficial.patches : relativity Server Time
19 Mar 2026 01:10:57 EDT (-0400)
  relativity (Message 11 to 14 of 14)
Subject: Re: relativity
Date: 4 Dec 2002 03:30:06
Message: <web.3dedbae45d040d8dc571aa6c0@news.povray.org>
>It depends on whether you are trying to approximate relativistic effects or
>actually model them.
Assuming we want to be able to model the actual effects, would it be
possible to do it by modifying the POV source code?
Rohan _e_ii
Date: 4 Dec 2002 14:09:30
Message: <chrishuff-9BC854.14063004122002@netplex.aussie.org>
In article <web.3dedbae45d040d8dc571aa6c0@news.povray.org>,
I don't think you can write something that simulates *all* the effects,
it is probably completely impractical to do. The answer depends on how
much you want to simulate in POV, but doing anything of any complexity
would take a huge amount of work. Also, POV is not a simulation program,
it's a renderer. Many things are "faked" for speed.
It would be possible, but impractical. More work than starting from
scratch, and wouldn't have any real advantages.
http://tag.povray.org/
Date: 19 Jan 2003 23:25:02
Message: <web.3e2b79695d040d8dcaa7dedc0@news.povray.org>
>Rohan _e_ii
Rohan -
Are you still interested in adapting POVRay to Relativistic Ray Tracing?
I have an interest in such a project, if POVRay proves to be sufficiently
adaptable to allow it.
I have been comparing the Backlight solution to the POVRay solution.
I have compiled and tested both.  The POVRay 2.2 adaptation appears
to be one dimensional, since it will only render properly with the
velocity component along the Z axis (into or outof the screen).
Backlight works fine and is not limited to a Z velocity. But there is
the animation issue, as you said.
I need to modify the source code for a few added features for my
research. No decision as to which package to modify.  POVRay is a
candidate, as is Backlight, and a number of other similar pacakges.
You can find more information on my progress here:
http://www.HyperVisualization.com
I am interested in hearing about what you have learned, so far.
- Digital Don
  dbl### [at] dcgFXcom
  1-949-548-1969
Date: 28 Sep 2004 05:20:00
Message: <web.41592c505d040d8d5dc6697f0@news.povray.org>
> Would it be possible to create a patch for Povray that would allow it to
> turn it into a relativistic raytracer?
This discussion may well be dead, but if anybody is listening,
you'll find a modified version of Povray 3.5 at
http://www.maths.monash.edu.au/~leo/relativity/sr-photography/
You'll find sample images, animations and source files.
This version produces relativisticly correct images when the camera moves
relative  to the other objects in an other wise non-relativistic scene
(i.e. relativistic effects are only accounted for between the camera and
objects). This version also ignores any colour or intensity shifts that
arise from the relativistic motions.
Leo
