POV-Ray : Newsgroups : povray.unofficial.patches : Error handling during parsing Server Time
25 Jun 2024 18:33:24 EDT (-0400)
  Error handling during parsing (Message 1 to 8 of 8)
Subject: Error handling during parsing
Date: 17 Dec 2003 05:07:12
Message: <vu90uv8qe10h1kfnf0ho8ipt3voq1i1p19@4ax.com>
How hard would it be, and would it make any sense, to implement some
sort of error handling for parse-time errors? For example:
sphere {
  0, 1
    image_map {
      #try png "image1.png"
      #else png "image2.png"
      interpolate 2
      map_type 1
I'm not proposing this syntax, of course (yuck), but the idea is more
or less clear. Parsing goes on as normal but if a parsing error is
generated in a specified block, something else can be said to happen
instead of just aborting.
Probably the only thing this is potentially useful for is for file
operations (#include, #fopen, image_map, density_file, bump_map,
texture_map etc.) Things like division by zero, input out of range,
array range check failure etc. can be handled manually with proper
programming, but for file operations there is currently no way. I
guess it would be simpler to implement an #if_exists or similar not so
horrible keyword that can check if a file exists in the Library_path
but a more general error handling mechanism, if implemented properly,
could make things easier even in cases where it is not the only
option.
What do you guys think?
Peter Popov ICQ : 15002700
Subject: Re: Error handling during parsing
Date: 17 Dec 2003 06:30:11
Message: <3fe03e43$1@news.povray.org>
	Can't you check whether a file exists or not with an INI
Pre_Frame_Command  command, which then creates a copy or link to
this file using a generic filename, and use this generic filename
in your POV script ?  I guess something similar is done in some
ini files (ini/ directory).
	- NC
Date: 17 Dec 2003 06:37:31
Message: <2rf0uvgs063ijqivd14srq88lu2jireo8h@4ax.com>
On Wed, 17 Dec 2003 12:30:11 +0100, Nicolas Calimet <pov### [at] freefr> wrote:
... with file_exists() in SDL of 3.5?
ABX
Date: 17 Dec 2003 10:04:10
Message: <3fe0706a@news.povray.org>
> texture_map etc.)
  How about just using file_exists()? (See section 6.1.3.6 of the POV-Ray
documentation.)
Date: 17 Dec 2003 11:35:01
Message: <Xns9454B2DECCF7Bseed7@netplex.aussie.org>
During writing mesh generation macros I often wished there woud be a try
except thingy. There are cases where POV-Ray just continues parsing
although the results are wrong, for example nomalising a zero length
vector.
Ingo
Date: 17 Dec 2003 11:52:06
Message: <85e6b1-a3b.ln1@triton.imagico.de>
> vector.
But this is not the kind of situation a try .. except block should be
used for.  You can easily solve this with a simple #if.
A try .. except would be useful for something like what Peter mentioned
if you do not only want to check for the existence of a file but also
want to handle the case the file exists but is not a valid png image.
Last updated 25 Oct. 2003 _____./\/^>_*_<^\/\.______
Date: 17 Dec 2003 14:11:04
Message: <Xns9454CD541C618seed7@netplex.aussie.org>
Yes,
Ingo
Date: 18 Dec 2003 06:59:29
Message: <qr43uvcbcktf1doelq09pr58ievj8vfm5e@4ax.com>
>documentation.)
You can check whether the file is there but not if does not generate a
parsing error. It can be an invalid image file, invalid density file,
or simply an include file generated from an external utility that for
some reason gives an error. You and ABX are right though, in that
file_exists() should be enough in most cases. Just not all.
File i/o aside, there are situations where some primitive exception
handling comes to the rescue. Even for debugging if not for release.
In any case such a feature could be useful for parse-intensive
applications such as particle systems, surface subdivision, your own
and Chris' mesh macros etc.
