POV-Ray : Newsgroups : povray.unofficial.patches : Re: POV's splines Server Time
16 Apr 2026 08:06:30 EDT (-0400)
  Re: POV's splines (Message 11 to 16 of 16)
Subject: Re: POV's splines
Date: 26 May 2004 06:13:51
Message: <nrq8b056ai774uuc6vrk12krbrcqkjt1v9@4ax.com>
On Wed, 26 May 2004 05:24:11 -0400, "David Wallace" <dar### [at] earthlinknet>
wrote:
> Sorry, generating meshes from splines is not trivial, especially when you
> have a parametric surface with u = "clock value" and v going around the
> spline.
I'm not sure I understand you. If u=clock then it is constant per scene (if it
is clock of animation). If you mean u=clock as being parameter of the spline
then most probably you mean different spline as for v parameter.
> The issue comes from finding a consistent "normal" vector to the
> spline to start the mesh circle.
If the spline is closed then finding normal at the end is equally difficult on
start/end as in the middle. Just input for calculating it changes, but
algorithm is the same. I coded it a few times and I'm pretty sure it was done
similar way in http://members.home.nl/seedseven/#param and
http://members.home.nl/seedseven/#lathe as well. Of course those are not
perfect solution but non approximation if perfect.
ABX
Date: 26 May 2004 06:27:53
Message: <40b47129$1@news.povray.org>
Again, are there any macros available to create mesh *prisms*? So far I
have only heard talk about lathes and sors... Prisms are more difficult
in my opinion.
Rune
rune|vision:  http://runevision.com **updated Apr 27**
POV-Ray Ring: http://webring.povray.co.uk
Date: 26 May 2004 06:46:11
Message: <1ct8b0t8rstib5a4k1th2drimk28tvaoho@4ax.com>
On Wed, 26 May 2004 12:28:14 +0200, "Rune" <run### [at] runevisioncom> wrote:
> in my opinion.
Obviously.
ABX
Date: 1 Jun 2004 03:03:33
Message: <40bc2a45@news.povray.org>
My interpretation of an n-sided prism mesh is a 4 by n structure:
Row 1: Radius 0, initial center
Row 2: Radius r, initial center
Row 3: Radius r, final center
Row 4: Radius 0, final center
What is your interpretation?
"Rune" <run### [at] runevisioncom> wrote in message
news:40b47129$1@news.povray.org...
> in my opinion.
> Rune
> 3D images and anims, include files, tutorials and more:
Date: 1 Jun 2004 03:42:20
Message: <Xns94FB62BDC766Fseed7@news.povray.org>
|_____  \
______|   /
|_______/
This is the kind of situation Rune is referring to, I think.
Ingo
Date: 1 Jun 2004 04:36:17
Message: <kofob0dd8sso6k70buc9egarndskqd2mhp@4ax.com>
On 1 Jun 2004 03:42:20 -0400, ingo <ing### [at] tagpovrayorg> wrote:
> |_____  \
> ______|   /
> |_______/
I think the most difficoult problem is hole within prism (subshape):
   ________
  \__/  \__/
as in http://www.povray.org/documentation/view/50/#s03_04_03_03
ABX
