A WinPOV pvengine.exe build containing an OpenGL wireframe preview patch
has been made and is available at
http://www.daylongraphics.com/other/povgl/povglbin.zip
Source code available at
http://www.daylongraphics.com/other/povgl/povgl.zip
Ray Gardener
Daylon Graphics Ltd.
"Heightfield modeling perfected"
Tried it ...... liked it
Triangles, polygons, cones, and heightfields
now have specific tesselators.
Ray Gardener
On Wed, 11 Jun 2003 01:56:47 -0700, "Ray Gardener" <ray### [at] daylongraphics com>
While polygons and cones issues I understand, can you elaborate what kind of
specific tesselators you applied to triangles and heightfields ? Aren't they
already tesselated ? Or do you mean "tesselators" as extraction of already
available data ?
ABX
of
they
> available data ?
I suppose a better term would be "vertex extraction"
but most of the time, the process is similar to tesselation.
Triangles definitely don't get tesselated since their
vertices pass directly through to the wireframer.
Heightfields are a regular grid of elevations
bounded in some 3D box, so a tesselation pass
has to occur to extract vertices. In fact, there
are many tesselations possible for a heightfield,
depending on LOD and inter-cell elevation interpolation.
I will likely have to copy Leveller's auto-LOD
tesselator as well, so that distant parts of an HF
show fewer wireframe lines -- a dense HF right now
shows up as mostly as a black blob. The current
tesselator connects each HF pixel quartet with
four lines.
If a displacement shader was used, then any primitive,
even a triangle, would need tesselation (but there'd
be little reason for a wireframe preview to show
displacement shader effects, except maybe to
examine a single primitive during shader development).
Ray
Lathe, mesh, and plane objects now preview
using specific wireframing methods. I believe
I've also patched all primitives now, so
there shouldn't be any more crashing/freezing.
Non-linear spline lathe objects wireframe crudely;
instead of tesselating the spline between segment points,
I just connect the points directly.
Plane objects draw using a light gray color
to avoid competing with other objects.
Source: http://www.daylongraphics.com/other/povray/patches/povgl.zip
Binary: http://www.daylongraphics.com/other/povray/patches/povglbin.zip
The website for the patch has also been moved, to
Ray Gardener
Subject: Re: OpenGL patch update (June 14/2003)
Date: 15 Jun 2003 03:17:34
Message: <3EEC1D8E.95C95974@gmx.de>
I could not yet get any scene to render correctly with it. Geometry seems
correct to some extent but the view is messed. See for example
'rad_def_test.pov' in the official sample scenes.
You should add a copy of the POV-Ray licence to all packages.
Last updated 28 Feb. 2003 _____./\/^>_*_<^\/\.______
Yeah, that file's camera is a tough one for the
wireframer to handle. Anything that uses "look_at",
actually, is likely to be off. I have to keep
working on the camera support.
Can do.
Ray
In article <3eebc386$1@news.povray.org>,
Have you considered using quick_color to define the color for OpenGL
drawing?
Christopher James Huff <cja### [at] earthlink net>
POV-Ray TAG: chr### [at] tag povray org
http://tag.povray.org/
In article <3eec2be7@news.povray.org>,
You should be able to translate any perspective or orthographic camera
pretty directly into OpenGL...what are you doing that makes it so hard?
Just let the existing code parse the camera, and use the values it comes
up with.
