POV-Ray : Newsgroups : povray.unofficial.patches : pattern & texturing Server Time
24 Jun 2026 19:56:24 EDT (-0400)
  pattern & texturing (Message 1 to 4 of 4)
Subject: pattern & texturing
Date: 10 Mar 2000 15:09:12
Message: <8EF3D3D87seed7@204.213.191.228>
height_field {
   pattern 200,200 {
      hf_gray_16
      wrinkles
      scale 0.1
      color_map {
         [0  , rgb 0]
         [0.4, rgb 0.4]
   translate -0.5
   rotate <-90,0,0>
   scale <20,20,2>
      wrinkles
      scale 0.1
      color_map {
         [0  , rgb 0.5]
         [0.4, rgb 0.5]
         [0.4, rgb 1]
What transformations do I need put here, to make the pigment exactly match
the heightfield?
Ingo
Subject: Re: pattern & texturing
Date: 10 Mar 2000 16:08:29
Message: <38c9644d$1@news.povray.org>
>the heightfield?
       warp {planar y 0}
       translate -.5
       scale <20,20,2>
These are my opinions.  I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
Date: 10 Mar 2000 18:23:05
Message: <8EF4EBD0seed7@204.213.191.228>
Ron Parker wrote:
>       warp {planar y 0}
>       translate -.5
>       scale <20,20,2>
Thanks Ron, that's it. Never thought of planar warp. Actually I'm not sure
I completely understand how it works. The helpfile is a bit cryptic for
this one.
Is it like rendering plane{y 0 Texture}, and use the resulting image as an
image map? An imagemap is projected in the xy-plane, that's the reason for
the absence of a rotation around the x-axis. If this is so the translate -
0.5 can be commented out, but it can't, it gives a different result.
Re-reading this and after some more experiments I see the light (I think).
A translation <-0.5,-0.5,0> also does it. It's just like an imagemap.
All this looks like a promising way to make old wall with parts of the
stucco coming off.
Ingo
Date: 13 Mar 2000 08:09:13
Message: <38cce879$1@news.povray.org>
>image map?
Yes, that's exactly it, though I see you already figured that out for yourself.
In fact, I asked MCB to add the planar warp precisely because I wanted to have
a way to texture height fields made from patterns.
