POV-Ray : Newsgroups : povray.unofficial.patches : povr features required in official Server Time
16 May 2026 13:27:41 EDT (-0400)
  povr features required in official (Message 1 to 9 of 9)
Subject: povr features required in official
Date: 26 Feb 2023 07:00:00
Message: <web.63fb493a78f1b563816b7cd96cde94f1@news.povray.org>
hi,
as per the subject, I have tried to .. brow-beat CC to consider some of the nice
'povr' features you added, when the opportunity arose talking about the
broken-on-Linux RTR feature.
so, regarding RTR, I want to find out what (pretty much) exactly was the
difference to the Windows version (and 'povr').  my guess was/is, essentially a
pointer not pointing to the correct buffer, as everything appears to work except
the preview window.
have several more questions, but would (probably) prefer to ask those in
private.
regards, jr.
Subject: Re: povr features required in official
Date: 26 Feb 2023 12:29:43
Message: <63fb9707$1@news.povray.org>
On 2/26/23 06:59, jr wrote:
> hi,
> the preview window.
IIRC. The only thing you need to do to activate the existing rtr feature
with 'unix' compiles in v3.8+ branches is to define a variable called
RTR_HACK.
There were a couple of issues / bugs as I recall which are fixed in the
povr source. First was that RTR_HACK didn't wrap all the rtr related
code - why it appears to be there, but broken with unix compiles. There
was too a bug where AA worked only for the first frame or two of an rtr
animation - true no matter the Operating System. Might be some other
stuff, but nothing popping into my head.
There is too a POV_RTR_DEBUG define - but I don't 'think' it currently
used. It might be in certain sets of code.
The povr fork has gone on to add additional features as you know. All
should be wrapped with RTR_HACK as in:
#ifdef RTR_HACK
#endif
> private.
I'll email you from my gmail account. I hardly use it these days, but it
is the account where I've tried to keep most POV-Ray email.
Bill P.
Date: 1 Mar 2023 23:15:00
Message: <web.64002217f0de317c9b4924336e066e29@news.povray.org>
[Windows 10, and using v3.8.0 beta 1, already compiled]:
Just tested +kla +rtr, and AA does work with it. It has been awhile since I used
the real-time animation feature-- probably on an older Win 7 machine a couple of
years ago.
The only trouble I'm currently having is getting the animation to stop! On my
newer and faster machine, hitting the GUI's 'stop' button sometimes works,
sometimes doesn't. It depends on how fast the animation is running. Shutting
down POV-ray is then the only way to end the process (AFTER hitting the stop
button repeatedly)-- otherwise, it would probably run until the year 10,191 :-O
Here's something subtle that I also just noticed: In this 'runaway' condition,
and after stabbing at the 'stop' button with no result, the animation will
sometimes suddenly speed up even faster(!). My machine's processor fan also
quiets down-- as if there is suddenly no more CPU-processing taking place. It's
like the animation is now simply playing back from a memory cache(?).
Date: 2 Mar 2023 17:21:29
Message: <64012169$1@news.povray.org>
> years ago.
Hmm. I'm pretty sure AA modes 1 & 2 stop working completely after frame
2 or 3. It's running, but it doesn't do anything after a while because
the internal box sizes shrink on every recursion and never get reset.
Yes, this seems to be a problem more so on windows than unix/linux but
it happens there too sometimes. There is I believe a github issue open
on the problem. Little bells... I 'think' more often with SDL1.2 than
SDL2.0/X11 an on unix/linux the preview window needs to be in 'focus' /
active.
With the povr branch I broke out the cylic control as it's own thing and
the default is to run through the cameras only once. Also means +kla /
clockless_animation now means 'clockless animation' and not 'cylic
clockless animation'.
// Use +kc (Cyclic_Animation=true) for cylic / continuous renders
// looping through cameras.
Bill P.
Date: 3 Mar 2023 03:40:00
Message: <web.6401b0b6f0de317c9b4924336e066e29@news.povray.org>
I had to double-check this, to prove it to myself ;-)  It does seem to be
working OK.
I let my animation cycle for several minutes(!), with a '20-camera animation'.
The attached images are screenshots of 'camera 19', then blown up 200%.
> active.
That appears to help with the Windows version too, if the animation isn't
playing *super*-fast. Thanks.
Download 'aa_with_kla_rtr.jpg' (162 KB)
Preview of image 'aa_with_kla_rtr.jpg'
Date: 3 Mar 2023 03:55:00
Message: <web.6401b4b8f0de317c9b4924336e066e29@news.povray.org>
Forgot to mention that the "CL" lettering in the images is not being
anti-aliased, by mistake; the reason is that I had set its texture{diffuse...}
value to 20, not 1...and anti-aliasing begins to fail with super-bright objects
>> 1.0
Date: 3 Mar 2023 05:57:43
Message: <6401d2a7$1@news.povray.org>
> I had to double-check this, to prove it to myself 😉  It does seem to be
> working OK.
OK. Thanks!
I'll put it on the list to again review in povr. I'd first noticed it
with povr's, again truly random jitter with and big jitter values (>1).
Maybe I did something which caused the problem while banging on code! Or
maybe the windows version is for some reason different - in official
POV-Ray code, RTR doesn't work on unix/linux machines.
Hmm, I got the compiles set now to turn off the duplicate vector zeroing
on allocation. Maybe the duplicate zeroing was covering some other
behavior as I've found quite a few times already. To test such thoughts
is why there is the povr configure option:
--enable-vector-zeroing enable old, nearly always unneeded vector zeroing.
Bill P.
Date: 3 Mar 2023 08:35:40
Message: <6401f7ac$1@news.povray.org>
On 3/3/23 05:57, William F Pokorny wrote:
> OK. Thanks!
Alright. I both didn't remember well and I never completely understood
what was happening... This is only a povr big jitter +j(>1.0) issue.
First jitter must be on. This is me not remembering - and, IIRC, it is
on by default with recent POV-Ray releases, but not in povr.
Plus! The user value must be larger than 1.0 for the issue to show
itself - which can only happen with my povr branch. The official release
jitter can only be on or off. Somewhere the jitter value is getting
reset/restored to 1.0 after each RTR frame - though in a quick look I
don't see where!
I too continue to get AA in all my RTR frames, but povr's big jitter
goes to a value of 1.0 after the first frame.
Thank you, Kenneth, for straightening me out! :-) I've added some notes
to the source to jog my memory down the road...
Bill P.
Date: 3 Mar 2023 15:20:00
Message: <web.640255d3f0de317c9b4924336e066e29@news.povray.org>
Yes, in the Windows version the AA jitter is on by default.
I'm glad that it helped!
