POV-Ray : Newsgroups : povray.unofficial.patches : UberPOV 1.37.0.0-beta.2 released Server Time
24 Jan 2026 19:41:57 EST (-0500)
  UberPOV 1.37.0.0-beta.2 released (Message 14 to 23 of 23)
Subject: Re: UberPOV 1.37.0.0-beta.2 released
Date: 25 Nov 2013 22:33:07
Message: <52941673$1@news.povray.org>
On 11/25/2013 03:48 PM, clipka wrote:
> Am 25.11.2013 21:14, schrieb James Holsenback:
>> On 11/24/2013 11:11 PM, James Holsenback wrote:
>>> Rendered 379904 of 705600 pixels (53%)
>>> Cannot access data in file.
>>> Rendered 380928 of 705600 pixels (53%)
>>> Fatal error in renderer: Frontend halted render.
>>> Dunno if it was related to the above problem ... just thought I'd
>>> mention it anyways
>> decreased +am3 aa depth from +r6 to +r4 and abort went away ...
> This must be something deep in the bowels of the POVMS message-passing
> code; can you try the following - in source/base/povmscpp.cpp, replace all
>      throw POV_EXCEPTION_CODE(pov_base::kFileDataErr)
> with
>      throw POV_EXCEPTION_CODE(pov_base::kFileDataErr, "FUBAR: ###")
error: macro "POV_EXCEPTION_CODE" passed 2 arguments, but takes just 1
Date: 26 Nov 2013 07:43:01
Message: <52949755$1@news.povray.org>
Am 26.11.2013 04:33, schrieb James Holsenback:
>> all
>> with
My bad - that should have been:
     throw POV_EXCEPTION(pov_base::kFileDataErr, "FUBAR: ###")
Date: 26 Nov 2013 10:50:10
Message: <5294c332$1@news.povray.org>
>>> all
>>> with
This run got a little farther .... used +am3 aa depth +r5
Rendered 553984 of 705600 pixels (78%)
Belch: 1494
Rendered 555008 of 705600 pixels (78%)
Render failed
btw: amd x2 250 is 32-bit dual core ... fwiw: 3.1.10-1.29-desktop kernel
opensuse 12.1
Date: 26 Nov 2013 11:23:59
Message: <5294cb1f@news.povray.org>
Am 26.11.2013 16:50, schrieb James Holsenback:
>>>> all
>>>> with
> Belch: 1494
> Render failed
> opensuse 12.1
Duh.. sure it's 32 bit? All I can find on the 'net says that it must be
either an "AMD Athlon 64 x2", or an "AMD Athlon x2" - but the latter is
a 64-bit thing, too. Even the notebook variant is.
Still, you're possibly running a 32-bit OS on it, so that brings integer
size issues back on the list of suspects.
Date: 26 Nov 2013 11:32:25
Message: <5294cd19@news.povray.org>
>>>> all
>>>> with
> Belch: 1494
Still doesn't make much sense to me. Mind e-mailing the complete scene +
all render settings? (See the dev newsgroup for my e-mail address).
Date: 26 Nov 2013 12:16:56
Message: <5294d788@news.povray.org>
>>>>> all
>>>>> with
>> Belch: 1494
a little bit too big to email ~15MB, so I put it on my wiki testbed ...
see your email for the link
Date: 26 Nov 2013 12:31:29
Message: <5294daf1$1@news.povray.org>
Am 26.11.2013 18:16, schrieb James Holsenback:
Thanks, but I guess I've nailed down the culprit already - after
accidently getting my Windows system into swap hell by "nothing more"
than cranking up the AA mode 3 quality settings (something like +am3
+ac0.999 +a0.001 +r9). The quality settings shouldn't have any effect on
the memory consumption during AA mode 3, but obviously they do.
That was the clue I needed. Turned out to be a stupid bug, actually.
Date: 26 Nov 2013 12:31:47
Message: <5294db03@news.povray.org>
>>>>>> message-passing
>>>>>> replace
>>>>>> all
>>>>>> with
>>> Belch: 1494
another thought ... might be worth it to have a quick look at latest
Coverity scan results. I've not looked so your mileage may vary
Date: 26 Nov 2013 12:43:34
Message: <5294ddc6$1@news.povray.org>
Am 26.11.2013 18:31, schrieb clipka:
BTW, the render abort you experience is probably due to an excessively
large chunk of memory being passed from one of the render threads to the
front end.
Date: 26 Nov 2013 12:48:48
Message: <5294df00$1@news.povray.org>
Am 25.11.2013 05:11, schrieb James Holsenback:
You might want to try the newest version from the "master" branch; I'm
quite sure it fixes your issue.
