POV-Ray : Newsgroups : povray.unofficial.patches : to clip or not to clip... Server Time
11 Jul 2026 11:25:48 EDT (-0400)
  to clip or not to clip... (Message 1 to 7 of 7)
Subject: to clip or not to clip...
Date: 30 Mar 2005 15:48:35
Message: <424b10a3$1@news.povray.org>
Hi all:
     Being a bit upset with the ultrabright artifacts produced by focal
blur while doing some HDRI tests, and after failing to alleviate them
with insane amounts of blur_samples, confidence and variance, I decided
to take my first look ever to the source code....
     I was sure to be wasting my time looking at something I will not
understand, but surprisingly, I found really quickly a call to
Clip_Colour() commented out on render.cpp, inside the focal_blur()
function. I restored that line back and just compiled again... you have
the results posted on p.b.i: both images where rendered using 35 blur
samples.
     I think I will be using this for scenes with extreme artifacts,
while waiting for MegaPOV 1.2... ;) (I still prefer the unclipped
version when there are not many artifacts visible, of course).
Jaime
Subject: Re: to clip or not to clip...
Date: 30 Mar 2005 18:04:50
Message: <424b3092@news.povray.org>
  The problem is exactly the same as with antialiasing: Preclipping
will always produce nice and smooth results (which is what people
usually want) but subpixel-sized brighter-than-1 details will be more
or less lost. Postclipping behaves in the exact opposite way:
Subpixel-sized details will show up, but brighter-than-1 pixels
will have ugly aliasing artifacts.
  The former works ok in 99.9% of cases but is still not perfect.
Date: 30 Mar 2005 18:48:55
Message: <424b3ae7$1@news.povray.org>
I don't think it's the job of antialiasing to make tiny subpixel bright
stars and the like show up. This is the job of some kind of glare filter
(which however doesn't exist in official POV-Ray, but that's another issue)
that is applied before AA. This is why I find pre-clipping for AA to be
correct.
Focal blur on the other hand should be applied before clipping, since focal
blur, just like glare effects, should be able to make small ultra-bright
spots become large still-rather-bright spots. The problem with artifacts
seem to me to only occur because AA (with clipping after the focal blur but
before the AA) is disabled when focal blur is enabled. I see no reason why
both can't be enabled at the same time.
Wouldn't the problem in Jaime's specific case here be solved if AA and
traditional focal blur (that is, no pre-clipping) could be enabled at the
same time? I'm not sure, but it sounds likely to me at least.
Rune
rune|vision:  http://runevision.com
POV-Ray Ring: http://webring.povray.co.uk
Date: 1 Apr 2005 02:19:07
Message: <424CF6B7.371A6494@gmx.de>
Jaime Vives Piqueres schrieb:
> Hi all:
> samples.
As others have said this is exactly the same as with antialiasing.
Note that next MegaPOV will offer a solution to apply whatever you want
- before or after antialiasing and anything between clipping or not
clipping.
-- Christoph
Date: 1 Apr 2005 03:02:20
Message: <424d000c@news.povray.org>
   Yes, I know, but with focal_blur, HDRI and normals, it is really too
ugly... there are bright pixels scattered around highlights (the size of
them depending on the amount of blurring) that you can't avoid even
using the best settings.
> clipping.
   That would be very useful... thanks in advance!
Jaime
Date: 3 Apr 2005 04:58:00
Message: <424fb018$1@news.povray.org>
Clipping before focal blur will have a consequence that you may not have
thought of. Have you ever seen pictures of things at night, where there are
lights in the out-of-focus background? Notice that the lights appear like
bright circles; this is because their extreme brightness outweighs the
nearby objects in the area that they blur into. If you clip before blurring,
then this won't happen and the lights won't look as bright as they are.
The proper way to do what you're trying to do, is to first separate the
focal blur from anti-aliasing. They are essentially two different
procedures, but POV-Ray mixes the two because it's convenient and faster to
do them both at once. However, to avoid the ugly effect but keep the effect
I mentioned above, you must do the clipping after focal blur and before
anti-aliasing. This will slow things down as supersampled pixels will have
to have focal blur calculated on them multiple times; but then the results,
which may be very bright, will be clipped before averaging and in the final
result even very bright areas will be nicely anti-aliased.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 3 Apr 2005 07:14:00
Message: <424fcff8@news.povray.org>
Slime wrote:
> However, to avoid the ugly effect but keep the effect I
> blur and before anti-aliasing.
I agree. This is essentially exactly the point I was trying to make too.
Rune
