POV-Ray : Newsgroups : povray.unofficial.patches : Two simple patchs for 3.5 ( adapted from 3.1 ) Server Time
22 Mar 2026 09:50:33 EDT (-0400)
  Two simple patchs for 3.5 ( adapted from 3.1 ) (Message 1 to 7 of 7)
Subject: Two simple patchs for 3.5 ( adapted from 3.1 )
Date: 11 Jan 2003 10:52:27
Message: <3e203dbb@news.povray.org>
Sphere and plane acceleration.
Nothig special. Just warming for real one.
URL: http://www.ddmrm.com/graph/pov/pov_index.html
Dejan.
Subject: Re: Two simple patchs for 3.5 ( adapted from 3.1 )
Date: 11 Jan 2003 11:54:41
Message: <3e204c51@news.povray.org>
  It would be nice if there was a description of what you have done and
some measurements (good measurements, not something like 3s to 2s "speedup").
Date: 13 Jan 2003 03:58:16
Message: <3E228002.80505@free.fr>
Looking at the zip file for 3.5 sphere (and the #ifdef in particular),
he removed the length's adjustement of the depth for ellipsoid (removing
two divisions), as well as the transformation also for ellipsoid from
the object space to the world space (removing 2 Matrice.Vector products)
I have a feeling that either something else is missing or that the
#ifdef part is bogus and asking for trouble with CSG.
Date: 13 Jan 2003 04:08:12
Message: <3E228253.4050808@free.fr>
>> "speedup").
Also, looking at the zip for plane, he removes all transformations
matrix by adjusting instead the plane normal and origin instead (which
make sense for an infinite plane with only rotate/scale/translate).
I'm nevertheless wondering if this could have a side effect on
non-uniform texture. May be the plane patch is ok.
(Unless there is a way for a plane to first get a transformation, in
which case the removed code was not dead enough).
Date: 13 Jan 2003 09:57:45
Message: <3e22d3e9@news.povray.org>
Still a set of speed tests would be nice. (And naturally extensive testing
that these modifications don't break anything.)
Date: 14 Jan 2003 16:15:48
Message: <3e247e04@news.povray.org>
Le Forgeron >...asking for trouble with CSG.
Right. No more sphere patch.
If  Plane->Trans is under exclusive control of plane functions:
Translate_Plane, Rotate_Plane, Scale_Plane, Invert_Plane, Transform_Plane
everything is OK.
And it must be, beacuase all transformation of an plane goes thru them.
Dejan
Date: 15 Jan 2003 09:17:44
Message: <3e256d88@news.povray.org>
> everything is OK.
  The famous last words...
