POV-Ray : Newsgroups : povray.unofficial.patches : relativity Server Time
18 May 2024 17:02:59 EDT (-0400)
  relativity (Message 1 to 10 of 14)
Subject: relativity
Date: 28 Nov 2002 23:45:05
Message: <web.3de6ef98c20e2bf3c571aa6c0@news.povray.org>
Would it be possible to create a patch for Povray that would allow it to
turn it into a relativistic raytracer?
In case you don't already know, a relativistic raytracer is able to make
calculations for the finite speed of light as happens in the real world
(unlike the infinite speed used in normal raytracing). This allows to see
the weird effects that occur at velocities approaching the speed of light
(abberation, doppler shift, and increase in brightness in the direction of
motion).
There is a relativistic raytracer called Backlight, which uses a variation
of the Povray scene description language. The problem with it is its
features are very limited, and it is _extremely_ picky about syntax. One
missed comma, and it won't render, do the same in Povray, and it will
usually still be happy to render. Another problem with Backlight involves
making animations, you have to put hundreds of cameras in the scene - one
per frame of the animation.
Anybody think this could be done by modifying the Povray source code?
Rohan _e_ii
Subject: Re: relativity
Date: 29 Nov 2002 01:03:55
Message: <3de7034b@news.povray.org>
"Rohan Bernett" <rox### [at] yahoocom> wrote in message
news:web.3de6ef98c20e2bf3c571aa6c0@news.povray.org...
Practically impossible. You would be much better off writing a relativistic
raytracer from scratch. POV is big and complex, you would have to change
pretty much everything, and not everything it does would even make sense in
a relativistic raytracer. It isn't something you could just patch into POV.
It would be much more productive to work on Backlight instead: it already
does the basics.
Date: 29 Nov 2002 03:50:36
Message: <3DE728DE.AD19CB3@nospam_zip.to>
I seem to remember that there already is one, but for one of the older
versions (2.? I think)
I can't remember the link of find it on povray.org - Ken?
Bye,
Pabs
Date: 29 Nov 2002 07:15:43
Message: <3DE75AB4.9F2078E9@pacbell.net>
I don't recall one ever created for POV-Ray.
You are probably thinking of -
http://www.anu.edu.au/physics/Searle/Obsolete/Raytracer.html
Ken Tyler
Date: 2 Dec 2002 03:16:25
Message: <3DEB1661.AEA494BD@nospam_zip.to>
Nah - it was definately a POV patch
I found it thanks to google -
http://www.cs.mu.oz.au/~andrbh/raytrace/raytrace.html
Now why didn't I do that before?
Bye,
Pabs
Date: 2 Dec 2002 03:29:18
Message: <3DEB1967.CDCB5250@nospam_zip.to>
Theres a couple of cool mpg demos at http://www.cs.mu.oz.au/~amb/rrt/
Date: 2 Dec 2002 05:39:08
Message: <3DEB389B.8ECFC618@pacbell.net>
I stand corrected. First time I have heard of that patch. So much for knowing
"everything".
Ken Tyler
Date: 2 Dec 2002 15:36:38
Message: <3debc456@news.povray.org>
"Christopher James Huff" <cja### [at] earthlinknet> wrote in message
news:3de7034b@news.povray.org...
relativistic
in
POV.
> does the basics.
Perhaps it's not possible for the reasons you state, but it seems to me that
those effects could be approximated by camera manipulations and a little
post-processing.  Of course, that assumes a static scene where only the
camera is moving relative to the scene.  Obviously, if multiple objects are
moving with different velocity vectors that wouldn't work.
It depends on whether you are trying to approximate relativistic effects or
actually model them.
Subject: :)
Date: 2 Dec 2002 22:00:50
Message: <3DEC1DCC.B350EE83@nospam_zip.to>
> I stand corrected... So much for knowing "everything".
> Ken Tyler
: ) I think that must be the quote of the month if not year.
JJ
Bye,
Pabs
Date: 3 Dec 2002 20:29:00
Message: <chrishuff-D904E1.20255803122002@netplex.aussie.org>
In article <3DEB1661.AEA494BD@nospam_zip.to>,
Huh...it modifies POV-Ray 2.2, quite a bit easier to do than a more
recent version. I wonder if it does anything more than just changing the
camera ray directions, or if he had to disable any features...it looks
like it just adds one camera parameter.
http://tag.povray.org/
