POV-Ray : Newsgroups : povray.unofficial.patches : Density_file extention patch: a patch for 3D data Server Time
27 Jul 2026 02:27:52 EDT (-0400)
  Density_file extention patch: a patch for 3D data (Message 9 to 18 of 18)
<<< Previous 8 Messages Goto Initial 10 Messages
Subject: Re: Density_file extention patch: a patch for 3D data
Date: 29 Aug 2002 06:17:38
Message: <3D6DF4C1.6381E31F@gmx.de>
ABX wrote:
> > A macro for generating a density file from a function (using the file
> > writing routines) would be a useful addition.
> What about
>   function 100,100,100{...}
Hmm, interesting, you mean for use in:
#declare DATA3D2= function {
  pattern{
    density_file function 100,100,100{...}
    interpolate 2
But a 'save_file' option would be good (for the 2D version this would be
useful too BTW)
Date: 29 Aug 2002 06:21:16
Message: <3d6df59c$1@news.povray.org>
"ABX" <abx### [at] abxartpl> wrote in message
news:n8mrmusor79q44peol7b0d4f5jse5n4fjf@4ax.com...
> I will add this to http://abx.art.pl/pov/patches/patches.php (with all patches
> announced recently) as soon as possible.
Thanks.  But I am still working on the coding.
The [Endian] option does not work at present.
And binary data formats in various platform should be added.
R. Suzuki
Date: 29 Aug 2002 06:42:16
Message: <3d6dfa88@news.povray.org>
"Christoph Hormann" <chr### [at] gmxde> wrote
> I saw that after looking at the source code.  Some more documentation
> about the header fields would be good, what does 'cyclic' mean for
> example?
Thanks for the comments.  I will add more documentation and examples.
The 'cyclic' is used for the cyclic pattern but I have not tested it yet.
Maybe there is a bug.
R. Suzuki
Date: 30 Aug 2002 02:18:59
Message: <3d6f0e53$1@news.povray.org>
>   pattern{
>     interpolate 2
I have added this feature in the new patch uploaded today.
It also has a 'save file' option.
The below is an example code.
R. Suzuki
#version unofficial dfe 3.5;
#include "functions.inc"
camera { location  <25, 20, -40.0> look_at <0,0,0> direction 45.*z}
light_source { <1,1.4,-1>*5 color rgb <1.4,1.2,1.0>*1.7 }
#declare DATA3D2= function { pattern{
    density_file
      function 40,40,40 {f_noise3d(x*8,y*8,z*8)/4
                +f_sphere(x-0.5,y-0.5,z-0.5,0)}
//        df3 "povdata.df"
      interpolate 102
 isosurface{
   function{
     DATA3D2(x,y,z)
   contained_by{box{0.05,0.95}}
   max_gradient 3
   threshold 0.4
   texture{ pigment{color <0.8,0.7,0.7>}  finish{phong 0.30 phong_size 90}  }
   translate <-0.5,-0.5,-0.5>
Date: 30 Aug 2002 02:37:13
Message: <3D6F1298.90C2C927@gmx.de>
Great, but for the saving option i would rather use a different syntax
than the trick with the interpolation value.
Maybe:
    density_file
      save_file {
        df3 "povdata.df"
        [type 0|1|2]
        [format 0|1]
      interpolate 2
Date: 30 Aug 2002 02:43:30
Message: <8t4umu4ipja647objsmoee5al5f7nkt4fq@4ax.com>
On Thu, 29 Aug 2002 19:23:12 +0900, "R. Suzuki" <r-s### [at] aistgojp> wrote:
I have added your patch and have changed navigation and administration (under
construction). Would you like to specify which files you have changed exactly.
I assume pvengine.h and some other are distributed in zip only becouse they
contain 'unofficial' notes. My intention was to list only files required to
changed to turn on patch.
http://www.abx.art.pl/pov/patches/patches.php
ABX
Date: 30 Aug 2002 06:46:29
Message: <3d6f4d05@news.povray.org>
news:8t4umu4ipja647objsmoee5al5f7nkt4fq@4ax.com...
I've added '#ifdef DENSITYFILE_PATCH' in the source files for the
density_file patch.
The source zip file also contains a language specific patch for Japanese
Windows.
I added '#ifdef LANG_PATCH' for this.
R. Suzuki
Date: 30 Aug 2002 07:08:57
Message: <5bkumu8344sbve94bkqh3k0l9k27jsbnnl@4ax.com>
On Fri, 30 Aug 2002 19:48:24 +0900, "R. Suzuki" <r-s### [at] aistgojp> wrote:
> density_file patch.
Thanks, it helped me to remove not necessary files from database.
> Windows.
Thanks for pointing it. I have added this as 'Japanese Language Patch'.
Additionally I have added categorization by author so you are listed with
http://www.abx.art.pl/pov/patches/patches.php?Author=R.Suzuki
Mail me if you want to be listed otherwise.
ABX
Date: 30 Aug 2002 07:15:25
Message: <3d6f53cd$1@news.povray.org>
"Christoph Hormann" <chr### [at] gmxde> wrote:
>       save_file {
>         df3 "povdata.df"
>         [type 0|1|2]
>         [format 0|1]
This would be better.  But it requires more work.
R. Suzuki
Date: 27 Sep 2002 10:25:28
Message: <3D946A57.4A7FA579@attglobal.net>
Thank you very much for this patch.
I did run into a couple problems which  seem to be
driven by differences in platform and compiler.
1) In the file pattern.cpp I had to change the lines:
__inline float intp3(....)
__inline float intp3_2(...)
to
inline float intp3(...)
2) To prevent and endless loop after picking up the [Data]
token the following lines were changed in pattern.cpp:
char buf[256],w1[256],w2[256],Fname[256],w;
int x,y,z,sx,sy,sz,n,ofs=0,fmt=0,i,d;
to
char buf[256],w1[256],w2[256],Fname[256];
int x,y,z,sx,sy,sz,n,ofs=0,fmt=0,i,d,w;
I also found a couple of code changes which did not seem
to be  bracketed with #ifdef DENSITYFILE_PATCH
and #endif.
1) In pattern.cpp the line:
Tpat->Vals.Density_File   = NULL; //R.S. 17 Aug. '02
2) In pattern.cpp the lines:
  if (((i0&0xff)=='d')&&((i1&0xff)=='f')) return(0);
  else return (unsigned short)((((unsigned short)i0) << 8) | ((unsigned
short)i1));
should probably be:
short)i1));
#else
  return (unsigned short)((((unsigned short)i0) << 8) | ((unsigned short)i1));
#endif
Regards, Bill P.
> Comments and suggestions are welcome.
> R. Suzuki
