POV-Ray : Newsgroups : povray.unofficial.patches : New MegaPOV Server Time
27 Jul 2026 04:11:58 EDT (-0400)
  New MegaPOV (Message 13 to 22 of 32)
Subject: Re: New MegaPOV
Date: 2 Apr 2002 21:03:04
Message: <1103_1017799368@selliot>
On Tue, 2 Apr 2002 14:35:24 +0100, "Andrew Cocker" <big### [at] mariner9fsnetcouk>
wrote:
> Well, I'd *definitely* like to see the inclusion of HDRI, and subsurface
> scattering if possible. Dunno about the latter, but I think the former is
> possible. Also, am I correct in thinking that there is room for improvement
> still in the radiosity solving section of POV-Ray.. I think I read it
> somewhere on these newsgroups.. although maybe that will have to wait until
> POV-Ray 4.
Yeah to subsurface scattering! You can use media, but if you specifically want to use
a thin, single
layer mesh that has no 'interior', media won't work. Not to mention it being
significantly more
complicated to get right.
Another item would be some sort of adaptive smooth mesh. In general getting any mesh
to look good
require either a rediculous number of triangles or the scene being done at sufficient
distance from the
model to 'hide' the flat surfaces. This and the lack of an easy non-media way to do
subsurface
scattering are the main reasons why models noever look real, unless you are using ones
that are very
high quality (like those produced by companies like Dreamworks). So I have wondered
for a while if
some way could be found to create additional subdivisions and smoothing with triangles
whos surfaces
are nearly parallel to the camera direction and are thus most visible. A more complex
model will always
be better, but being very bad at mesh model building and nearly as bad at post work
needed to clean
up the artifacts. Besides with animation you don't generally have the luxery of
checking every frame of
a long animation. A method that could take a realtively small slice of time to
optimize the parts of a mesh
that contain visible problems would be worth it, especially since it is far less
likely to miss something than
the human doing the post work. ;)
Anyway, there are bound to be new things to keep adding.
Date: 2 Apr 2002 21:05:34
Message: <3caa636e@news.povray.org>
Some kind of pov-like code-based post-processing scripting language would a
nice addition to pov-ray. Especially for more realistic lens-flares.
Lens flares will be really realistic if the inner camera lens reflections
are simulated properly. But that has nothing to do with post-processing of
images.
Apache
http://geitenkaas.dns2go.com/experiments/
apa### [at] yahoocom
Date: 3 Apr 2002 06:58:10
Message: <3caaee51@news.povray.org>
  What do you mean "more realistic lens-flares"? I didn't know POV-Ray
supports lens-flares at all.
Date: 3 Apr 2002 09:45:02
Message: <3cab156e@news.povray.org>
> want to use a thin, single layer mesh that has no 'interior', media won't
> work.
Where should your subsurface scattering stop if you have only a single
layer? The clou with subsurface scattering is that there happens something
to your light _below_the_surface_, right? So there has to be a notion of
"inside" and "outside". That's why you need an object with well defined
inside and outside to get this thing working. The "inside" modifies the
light. That's what "media" does. So, using "media" for subsurface scattering
is natural. (However, "media" should be extended to support other scattering
functions.)
A "thin" mesh doesn't make much sense for subsurface scattering. In
particular, if the mesh is infinitely thin. Then you don't have an
"inside" at all!
Date: 3 Apr 2002 10:14:54
Message: <3cab1c6e@news.povray.org>
> > scripting language would a nice addition to pov-ray.
> I didn't know POV-Ray supports lens-flares at all.
What do you mean "support"? You can make all kinds of things with POV-Ray
that are not implemented as internal features. That includes lens flares.
Rune
Rune's World:  http://rsj.mobilixnet.dk (updated Mar 19)
POV-Ray Users: http://rsj.mobilixnet.dk/povrayusers/
POV-Ray Ring:  http://webring.povray.co.uk
Date: 3 Apr 2002 10:18:58
Message: <3cab1d62@news.povray.org>
  If you are talking about the different "lens flare" include files out
there, those are not lens flares. Those are colored discs put on front of
the camera.
  A true lens flare would simulate a camera lens and how light behaves with
it. (Something like this *is* possible at least in a limited way, but I don't
think it's very handy. :) )
Date: 3 Apr 2002 10:22:07
Message: <3CAB1EC4.3C0E306E@pacbell.net>
> the camera.
I recall a thread 3-5 months ago where someone modelled true lens flares
using the photon feature. Don't remember much about it though.
Ken Tyler
Date: 3 Apr 2002 11:49:28
Message: <3cab3298$1@news.povray.org>
> include files out there, those are not lens flares.
> Those are colored discs put on front of the camera.
The very concept of ray-tracing is just a faked version of how nature works.
However, it looks nice, so we don't care. The result is what counts.
Likewise with lens-flares. If they look like lens flares, then they *are*
lens flares. I don't see why you define one faked method as being real nut
another as not being real.
> how light behaves with it.
You said the word yourself: "simulate". If it's just a simulation, it's not
real (or "true").
Rune
Date: 3 Apr 2002 12:07:24
Message: <3cab36cc@news.povray.org>
  There's a difference.
  Lighting is based (more or less) in a physical model (eg. the usage of the
cosine as the falloff function for lighting comes from physics). The concept
and implementation of IOR is based on the physical model (the same math
applies). Photon mapping is based in a physical model.
  However, faking lens flares with colored discs is in no way based on any
physical model, nor any math from physics is used to make them. They are
just put "somewhere where they look good", without being based on anything.
> real (or "true").
  Simulation means (usually numerical) approximation. Since we can't have
infinite accuracy, things have to be approximated and simulated.
  However, whether this simulation is based on physical mathematics or
if it's just something "which looks good" but is not based on anything,
makes a big difference.
  POV-Ray does not support simulating lens flares. There's no math in POV-Ray
to calculate them. Period.
Date: 3 Apr 2002 13:24:54
Message: <3cab48f6@news.povray.org>
> There's no math in POV-Ray to calculate them. Period.
The only one talking about POV-Ray supporting simulating lens flares is you.
Neither Apache nor I used the words "support" or "simulating". I'm simply
saying that you can indeed "make" lens flares in POV-Ray, just like you can
make clouds, fire, bricks, human characters and all other kind of things,
even though they're not "supported" in POV-Ray and can't be "simulated".
If you disagree, feel free to contact Chris Colefax and ask him to rename
his Lens Flare Include File to "Colored Disc Placed In Front Of Camera
Include File". See if he cares.
Rune
