POV-Ray : Newsgroups : povray.unofficial.patches : HF height: bug report Server Time
28 Sep 2024 21:18:36 EDT (-0400)
  HF height: bug report (Message 1 to 10 of 10)
Subject: HF height: bug report
Date: 4 Aug 2001 20:38:54
Message: <3b6c959e@news.povray.org>
The following is an excerpt from express.c
(MegaPov 0.6a, lines 505 and below):
  if( hfield->Type & HFIELD_OBJECT != HFIELD_OBJECT )
    Error( "Cannot find height of non-height-field.\n" );
  if( ( Val < 0 ) || ( Val2 < 0 ) ||
    ( Val > 1 ) || ( Val2 > 1 ) )
      Error( "Height-field index out of bounds [0 1].\n" );
Since the precedence of 'not equal' is higher than that
of 'bitwise and', the very first line really means
  if( hfield->Type & 0 )
and thus the error message never appears. In fact,
optimizing compilers eliminate entire statement. I
quoted a little bit more than necessary just to illustrate
(and rant :-) how... unwise people use parentheses.
BTW (to those who are interested): this strange
precedence rule goes deep into the history of C...
From the very beginning, there were no such things
as 'logical and' and 'logical or' (that is, '&&' and '||'),
the only 'and' and 'or' operators were '&' and 'I',
respectively, serving as either logical or bitwise
based upon context ("truth-value-context"). When
their "pure logical" counterparts were introduced,
K&R were forced to stick with their current
precedence to maintain compatibility with existing
code.That's that.
Subject: Re: HF height: bug report
Date: 5 Aug 2001 07:34:15
Message: <3b6d2f36@news.povray.org>
A good compiler would issue a warning there (because the condition is
always false) and the bug would have been located immediately.
  However, as the POV-Ray source code issues about 10000 warnings I suppose
that no-one has full warnings turned on in their compilers (or if they have,
this specific warning gets buried under all the other 9999 ones).
  Warnings are always important and they shouldn't be taken lightly. This
ideology has not been followed in POV-Ray.
  Fortunately now that POV-Ray will be written in C++ it will be possible to
completely get rid of all warnings (C++ allows getting rid of certain
warnings the C version has and you can't do anything about it: Unused function
parameters: Just don't give the parameter a name).
Date: 5 Aug 2001 09:22:14
Message: <3b6d4886@news.povray.org>
In article <3b6d2f36@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
This bug is actually one of the many code quality problems in MegaPOV.  A
good developer should know which warnings are informative and which are more
like non-fatal errors.  Turn off the float-double conversion warning and you
get only very few warnings.
For example, would you consider the legal code ISO C/C++ "long I = 'abcd';"
worth a (by default on) warning?  Well, the gcc developers think so...
    Thorsten
e-mail: tho### [at] trfde
Date: 5 Aug 2001 09:23:53
Message: <3b6d48e9$1@news.povray.org>
In article <3b6c959e@news.povray.org> , "Vadim Sytnikov" <syt### [at] rucom>
This particular feature will probably be removed in future versions of
MegaPOV as it is not part of POV-Ray 3.5.  The suggested method is to use
"trace".
    Thorsten
Date: 5 Aug 2001 11:59:20
Message: <3b6d6d58@news.povray.org>
Thorsten Froehlich <tho### [at] trfde> wrote in message
news:3b6d4886@news.povray.org...
'abcd';"
Yes, definitely. Although it's legal, it is implementation-defined
(i.e. the characters are mapped into the execution character set
in the implementation-defined manner). BTW, that's the reason
behind the MKFOURCC macro in Windows.h.
That's especially important for POV-Ray. Just imagine porting code with
that constant to, say, ancient Honeywell Bull with 36-bit chars...
Date: 5 Aug 2001 12:57:38
Message: <3b6d7b02@news.povray.org>
In article <3b6d6d58@news.povray.org> , "Vadim Sytnikov" <syt### [at] rucom>
Exactly that is my point.  It isn't the business of the compiler to lecture
the programmer about the language definition in such a case.  It is clearly
specified as resulting in an implementation defined integer constant.  This
is a well-defined behavior and if the programmer isn't aware of it, i.e. by
doing a comparison like 'abcd' > 1234 it is at least very bad style (nearly
programming error).  However, declaring i.e. an enumeration with
multicharacter constants is fine, after all comparing an enumeration value
against an integer constant is bad style.
So why should a compiler issue a warning about something that is absolutely
legal?  Well, the simple answer is that it should shut up by default and
assume the programmer knows the standard.  A compiler should not assume an
incompetent programmer by default - and a multicharacter constant can hardly
be considered accidental.  Or should a compiler warn i.e. in a case like
"int i = 01;" because the programmer might have meant to write "0"?  If i
write a multicharacter constant I mean it, and it is a perfectly legal
program on every platform, thus the compiler does no need to "comment" it.
So because some stoneage non-standard hardware and software it has to be on
on every 32 and 64 bit processor?   I like that ... after all there is
nothing wrong with a character constant on a 36 bit system.  Of course it
would be different if the resulting value would not _fit_ into an "int".
But obviously a four character constant fits will into a "int" on every 32+
bit system.  On a system with 16 bit "int"s it would of course be
appropriate if the compiler would issue an error (or warning) if a constant
is out of range!
On the other hand, to force the programmer to use tricks to get the compiler
to shut up is far more dangerous and leads to bloated and unreadable code.
The programmer is the master of the compiler*, not the other way around!!!
    Thorsten
* IMO, very ambiguous code should be considered an error and there would be
no default warnings at all in a really good C/C++ compiler.  Of course, a
well-specified and implemented language would not have such problems in the
first place <sigh>
Date: 5 Aug 2001 17:41:21
Message: <3B6DBB69.3DA0F6F0@faricy.net>
POV gives about 10000 warnings on what warning level?  I keep my copy of
msvc on level 3.  On level 4 (highest) I get tons of crap I don't care
about like "assignment in conditional expression."  I know, that's what
I want!  On level 3 though I always try to get rid of the warning
messages my code makes.
But then, is msvc a "good compiler"?  ;)
(ya know, like "if( !(fil = fopen(...)) )")
Date: 5 Aug 2001 19:58:32
Message: <3b6ddda7@news.povray.org>
In povray.unofficial.patches Thorsten Froehlich <thorsten@trf.de> wrote:
: Or should a compiler warn i.e. in a case like
: "int i = 01;" because the programmer might have meant to write "0"?
  Actually 01 is an octal number ;)
  (In fact, that's another place where you can shoot yourself in the foot
with C. You might sometimes write something like "i = 011;" to "indent" the
number with other similar numbers and then you are surprised when the
program behaves very strangely...)
  This is actually one place where the compiler assumes that the user
really wanted an octal number and that it wasn't just a mistake.
Date: 5 Aug 2001 23:17:31
Message: <slrn9ms32e.2h8.ron.parker@fwi.com>
and is distinct from 0l.
#local R=<7084844682857967,0787982,826975826580>;#macro L(P)concat(#while(P)chr(
mod(P,100)),#local P=P/100;#end"")#end background{rgb 1}text{ttf L(R.x)L(R.y)0,0
translate<-.8,0,-1>}text{ttf L(R.x)L(R.z)0,0translate<-1.6,-.75,-1>}sphere{z/9e3
4/26/2001finish{reflection 1}}//ron.parker@povray.org My opinions, nobody else's
Date: 6 Aug 2001 07:03:06
Message: <3b6e796a$1@news.povray.org>
In article <3b6ddda7@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
Exactly.  And in my example (unlike 011) it wouldn't even make a difference
if one wrote 01 or 1.  So why does it make a difference if I write 'ab'? --
Both are features of the language.  They are both a bit "unexpected", but
still perfectly legal!
    Thorsten
