POV-Ray : Newsgroups : povray.unofficial.patches : Posts being removed Server Time
22 Mar 2026 16:11:57 EDT (-0400)
  Posts being removed (Message 1 to 4 of 4)
Subject: Posts being removed
Date: 14 Apr 2001 22:57:57
Message: <3ad90e35@news.povray.org>
Is there some reason why my posts are being removed from this newsgroup?
Subject: Re: Posts being removed
Date: 15 Apr 2001 07:29:44
Message: <281jdtklihpiedntkq356hp7fctqjj5hf5@4ax.com>
  Without even looking first at your message header I knew you were using MS
Outlook Express.
  This question and similar ones occur often enough to warrant an article in
the p.a.f-a-q group on how to use Outlook Express settings.
  In the event I have made an erroneous assumption, which posts in
particular are you referring to (thread Subject, date, etc.)?
Alan - ako### [at] povrayorg - a k o n g <at> p o v r a y <dot> o r g
Date: 15 Apr 2001 09:20:53
Message: <3ad9a035@news.povray.org>
Yep I DO use Outlook Express.  I don't think you made an erroneous
assumption...I did.  I looked in the options and there is a setting "delete
news messages XX amount of days after being downloaded.  It was set to 5
days.  Obviously I have erased my own messages!  That option is now turned
OFF.
Thank you!
"Alan Kong" <ako### [at] povrayNO-SPAMorg> wrote in message
news:281jdtklihpiedntkq356hp7fctqjj5hf5@4ax.com...
MS
> Outlook Express.
in
Date: 15 Apr 2001 10:16:24
Message: <3ad9ad38@news.povray.org>
"delete
> OFF.
I have it set to mark all posts as read when exiting a ng, and then delete
all read posts on OE exit, and manually compact..
PGP Public Key
