POV-Ray : Newsgroups : povray.unofficial.patches : Re: Request: deform Server Time
30 Sep 2024 13:20:18 EDT (-0400)
  Re: Request: deform (Message 1 to 3 of 3)
Subject: Re: Request: deform
Date: 9 Jan 2001 04:39:12
Message: <3a5adc40$1@news.povray.org>
Chris Huff wrote in message ...
> > I suggest that we begin to think of the possibilities of implementing
> > such functions. I personally believe that it could improve POV-Ray
> > significantly in some of the areas where it is currently not as
> > powerful as many other renderers.
> You're a little late...Wlodzimierz ABX Skiba
simpler is write just ABX :-)
> has already been working on
> a deform patch, which apparently can work on all objects
I have changed my previous syntax for simpler usage I think
instead next object in pov syntax I have putted deform into object modifiers
in example :
ttf {
  "arial.ttf" , "Hello world" 0, 1
  texture { ... }
  transform { translate rotate etc.. }
  deform { TYPE PARAMS }
also declaration of deforms will be available just like declaration of
transformations, textures or other things
#declare BestTwist = deform { twist .5 }
object {
  MyBox
  texture { MyTexture }
  deform { BestTwist }
Every deformation will be defined as something like pattern in pigments : twist,
envelope, curve, stretch etc followed parameters. I plan implement functions as
type of deformations after 3.5 release (I wait for specification of functions) -
deform{function{...}}
Rune's proposition of control points could be possible as part of this stuff but
... I thought about deformation depends of distance point to the bezier patch or
sth
current state of deform patch : geometry works fine, now I play with deformation
of atributes of textures applied to object
ABX
Date: 9 Jan 2001 12:30:56
Message: <chrishuff-D0CE27.12323509012001@news.povray.org>
In article <3a5adc40$1@news.povray.org>, "Wlodzimierz ABX Skiba"
I often copy-paste my own name... :-)
> modifiers
This does look like a better syntax. If your technique allowed warps to
be used as deformations, it would be perfect...maybe a compromise would
be a "deform" warp, but there will be a lot of duplication, since people
will want deforms that do the same things as many of the warps.
Is your technique still limited to deformations that can be "reversed"?
Christopher James Huff
Date: 10 Jan 2001 04:57:24
Message: <3a5c3204@news.povray.org>
yes I think there is compromise between my deform and warps
every deform has defined methods just like methods for objects
this way there could be simple to write type of warp
warp { deform { TYPE PARAMS } }
which call method not assigned to object
and calculate coordinates without duplication of code
I'll check it before release of patch
ABX
