POV-Ray : Newsgroups : povray.unofficial.patches : PVMegaPov Server Time
14 Jul 2025 09:47:58 EDT (-0400)
  PVMegaPov (Message 1 to 5 of 5)
Subject: PVMegaPov
Date: 19 Mar 2002 17:36:25
Message: <3C97C16D.5040400@atom.hp>
I have compiled pmp recently and i have some problems:
The first one: it works fine for simple scenes, but when i try to use
something more advanced, like #define (or its shortened version, $) i'm
in trouble: i can't modify the #define'd variables (it says "undeclared
identifier expected, but r found" - my variable was r here).
    Another problem: wherever I use arithmetics in translation/rotation
I get an error message : "no matching } in object(or anything else),
*(or / or - or +) found instead".
   My toys are: 8 x i686(Celeron), RedHat7.2 and pvm 3.4.3.
Thank you in advance.
Subject: Re: PVMegaPov
Date: 19 Mar 2002 19:41:03
Message: <3c97da9e@news.povray.org>
  AGAIK 'r' is a reserved keyword in megapov. You can't use it as a variable
name.
Date: 20 Mar 2002 12:17:36
Message: <3C98C3F7.A5341E67@aol.com>
sabin iacob wrote:
>>(it says "undeclared identifier expected, but r found" - my variable was
r here).
It's always a good idea to begin your variable names with a capital letter.
That way, you will never have an accidental conflict with a reserved
keyword.
Date: 20 Mar 2002 12:27:44
Message: <3c98c68f@news.povray.org>
Can you provide an example scene file for this?
Date: 21 Mar 2002 07:34:34
Message: <3C99D74E.6070408@atom.hp>
Thanks, it worked. As with the arithmetic operations, i have forgotten
to update the rendering script, so there was an +mv3.1 lying there and
messing up things.
