![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
[please correct any false assumptions in next paragraph]
I assume; when POVRay reads in a scenefile, it goes through the text
(skipping whitespace) until it finds a keyword, which it then converts
into something that the rest of the program understands. This might
involve looking ahead through the file to find a parameter (eg. when it
hits "sphere", it goes looking for the center and radius parameters) or
something.
My question; how far ahead does this look-ahead work? I have an idea for
a version of POVRay which will pass the scenefile to the parser in small
chunks (I'll explain why later), and I'd like to know how small I can
make those chunks without running into problems with look-ahead.
Please also inform me of any other problems this system might run into.
Thanks.
signature{
"Grey Knight" contact{ email "gre### [at] yahoo com" }
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
If you explain why now, we might be able to help you avoid povlegal pitfalls.
The parser does not work as you think it does, but the general answer to your
question is probably "a token's worth." However, the parser expects to be
able to go back and reread data it's already seen, and it expects to be able
to do so by opening a file and doing a seek.
#macro R(P)z+_(P)_(P)_(P+1)_(P+1)+z#end#macro Q(C,T)bicubic_patch{type 1u_steps
6v_steps 6R(1)R(3)R(5)R(7)pigment{rgb z}}#end#macro _(Y)#local X=asc(substr(C,Y
,1))-65;<T+mod(X,4)div(X,4)9>-2#end#macro O(T)Q("ABEFUQWS",T)Q("WSXTLOJN",T)#
end O(0)O(3)Q("JNKLCGCD",0)light_source{x 1}// ron### [at] povray org
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Well, I wanted to sort out some algorithims first so that Warp wouldn't
complain (j/k)
Basically, I wanted to see if I could store a .pov file as binary data
(with eg 0x10 representing the "sphere" keyword, 0x0C for "blob" or
whatever), and then compress that data into a file (I was thinking .pbz
for POV-Ray Binary Zipfile; also look what happens when you ROT13 it ;)
The idea is that the .pbz file will be much smaller than the .pov file,
so we can keep only the pbz data in memory, and translate it to text
when required by the editor or parser.
Hmm, perhaps we could just uncompress the data again if it wants to look
at old stuff?
These are all just ideas off the top of my head, I wanted to try and
realise it a bit more before I posted any detail.
signature{
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Well, you could always use a version of POV that doesn't need to keep the
.pov file in memory. :)
I don't think the editor would take too well to this sort of thing, actually.
The parser might be okay with it with some small modifications, though.
However, most .pov files that you would actually load into the editor are
fairly small in size anyway, and files that are just being rendered (but not
edited) are never actually in memory, so I can't see that you'd see much
improvement with these changes.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Ho hum. Can you think of anything in POV that *would* benefit from some
sort of compression? I'm just looking for something to experiment with
now...
signature{
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Oh, actually I just thought of one; sigfiles ;)
I'll just finish my *2* IRTC entries first...
> now...
signature{
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I can get you a few hundred povscript .inc files containing huge mesh2 data.
Maybe compressing those?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I forgot. The folks of the 'Internet Movie Project' have a povray 3.1
version that can use zipped file systems or something IIRC.
http://www.imp.org/
Apache
http://geitenkaas.dns2go.com/experiments/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> able to do so by opening a file and doing a seek.
I'm a little bit surprised by this, because - according to the docs
Section 6.2.2.5 - you can pipe a scene to povray. Is the complete scene
buffered internally?
Anyway, you can of course uncompress a scene file on the fly using zcat.
This would at least save hard disc space, but you probably know all this.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Wed, 06 Mar 2002 08:38:07 +0100, Thomas Willhalm
(in new 3.5 documentation standard input is mentioned in 5.2.3.2)
ABX
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
