POV-Ray : Newsgroups : povray.unofficial.patches : Hey, Warp (Tesselation patch: the fire test) Server Time
27 Jul 2026 05:52:39 EDT (-0400)
  Hey, Warp (Tesselation patch: the fire test) (Message 3 to 12 of 22)
<<< Previous 2 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Hey, Warp (Tesselation patch: the fire test)
Date: 5 Oct 2001 08:38:44
Message: <3bbda9d3@news.povray.org>
I recall trying to tesselate BlobMan objects and the bug showing up there.
Date: 5 Oct 2001 11:12:41
Message: <3BBDCDEB.773F74CF@atosorigin.com>
Any specific scene ?
I cannot try every values for the blobman parameters...,
I'm not immortal yet...
Date: 5 Oct 2001 11:12:59
Message: <3bbdcdfb@news.povray.org>
Oo - can't wait!
BTW which version does it run on? 3.1, 3.5, Megapov .6, .7 ?
- Nekar
Version: 6.0.282 / Virus Database: 150 - Release Date: 2001/09/25
Date: 5 Oct 2001 11:30:33
Message: <3BBDD219.712DD301@atosorigin.com>
Christoph Hormann wrote:
> > So, does anyone have some bogus generated mesh that I could try ?
> > (Possibly only with object from 3.1, because I have not Megapov installed,
> > so no isosurface, please).
> I don't have any specific object here you should try, but i think some
> CSG's,  blobs and text objects would be good examples to test.
I have done some tests with blobs already, but maybe not the Bogus blobs...
I have also my own set of test objects... BUT...
Given the fact that the initial bogus (sphere) only appeared when
moving the sphere, I may very well miss a bogus case that someone
already know about. So, I would like to perform a kind of private beta
(with scene from other people, even if I'm not yet ready to publish
the correction
[before that, I need to gain confidence with my analysis
of the cause of the problem {I'm nearly OK for the theory, and so far the
scenes I tested where fine, but know problem scenes are the better}]
Thanks for the suggestion of ttf ! I missed that basic one, as well as CSG
(I played with torus, superellipsoid, cylinder and so on, but still missed the
basic CSG and ttf one! I would better reopen the pov manual and check with
each finite solid primitive...
Date: 5 Oct 2001 11:37:25
Message: <3BBDD3B6.E11BF559@atosorigin.com>
Nekar Xenos wrote:
> Oo - can't wait!
You will have to. At least a little.
(Anyway, for this weekend, you should have the next 3.5 beta to install,
 or otherwise it will be expired for everybody,
so you will have something to do.)
Currently, only MY personnal 3.1 derivative... on Linux. The patch code is
not in a publishable state. But you will have the explanation sooner than the
code IF it is really the cause that I have isolated.
Maybe someone incorporated the initial patch of Warp (which was for
Megapov [UV mapping was required]) in a variant of Megapov ?
Date: 5 Oct 2001 11:51:24
Message: <3bbdd6fc@news.povray.org>
news:3BBDD3B6.E11BF559@atosorigin.com...
> Nekar Xenos wrote:
> > Oo - can't wait!
Will it work on Windoze?
- Nekar
Date: 5 Oct 2001 11:59:15
Message: <3BBDD8D3.2465C66D@atosorigin.com>
Of course, when someone with the ZinZin compilation system will have
 incorporated it in whatever (Mega)Pov version.
There is no Linux dependancy, It's just that I only have the compiler for Linux.
Pov is portable. Pov is great.
Date: 5 Oct 2001 12:44:06
Message: <3bbde356@news.povray.org>
I look forward to seeing this patch working and integrated into the next
incarnation of megapov based on the 3.5 code as I belive it to be
potentially one of the most useful additions to Pov. So good luck, fingers
crossed.
Mick
Date: 5 Oct 2001 14:18:28
Message: <3bbdf974@news.povray.org>
What Mick said... I'm dying to know if it was some little oversight, or some
bigger problem causing the buggy meshes.
Date: 6 Oct 2001 16:29:41
Message: <3BBF6BE1.5720D09F@free.fr>
Ok, Take a deep breath now and everybody try to relax.
Here come the reason for the bug of the moving sphere...
I would say it's a design assumption which turns out to be wrong, sometimes:
The Inside test and the trace test may disagree;
They should not, but they do in some occurences.
The decision to add a triangle is determined by the value of Inside
at each vertex of the Tetrahedron.
The triangle vertices are determined by the trace test between an outside/inside pair
of vertices.
Alas, the code assumes that if one vertex is outside, and the other one is inside,
then Intersection() will always gives a valid result.
If you really want to have fun (NOT), Try YOffs=3.5 in the sphere scene.
(Expect a Segmentation Fault, at render time, at least on my system!).
I successfully removed that bug by testing the Intersection() return
in CalcIntersection().
I had to choose a "good" answer when Intersect failed. I choose the middle
of the segment, but there is maybe a better values ?
Here some code, for those that want to try it:
        if (Intersection(&tess_intersect, info->Object, &tess_Ray))
        Assign_Vector(info->Intersection[outs][ins][0], tess_intersect.IPoint);
        if(Smooth)
            Normal(info->Intersection[outs][ins][1],
                   tess_intersect.Object, &tess_intersect);
       else
       { /* Cheating */
       Assign_Vector(info->Intersection[outs][ins][0], info->Coord[ins]);
       VScaleEq(Dir,-1/2);
       VAddEq(info->Intersection[outs][ins][0],Dir);
         if (Smooth)
              VNormalizeEq(Dir);
              Assign_Vector(info->Intersection[outs][ins][1],Dir);
If you do not believe me, the demonstration of the bug is left as an exercice
to the reader.
Last point, Because good news always comes with bad news, my test with the torus
gives strange results... Still another bug, but maybe not at the same place.
Other objects seems to have survived the tesselation.
