![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
anybnody knows? ;-)
Regards
Disnel
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: Why trace don't work with method 2 isosurfaces
Date: 17 Aug 2001 09:37:03
Message: <3b7d1dff@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Disnel <dis### [at] hlavacek-partner cz> wrote:
: anybnody knows? ;-)
I don't know the exact reason, but it just doesn't work and I have the
impression that nobody developing the code even cares. The method is anyways
obsolete in pov3.5, so the problem will disappear by itself.
7382340,3358,3900569407,970,4254934330},0)}// - Warp -
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I would normally care, were it not for that "obsolete in 3.5" thing.
plane{-z,-3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate
z*60#local a=a-1;#end translate-9*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{9-z*18rgb z}text{ttf"arial.ttf"
"RP".01,0translate-<.6,.4,.02>pigment{bozo}}light_source{-z*3rgb-.2}//Ron Parker
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 17 Aug 2001 10:12:17
Message: <3b7d2640@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Ron Parker <ron### [at] povray org> wrote:
:> I don't know the exact reason, but it just doesn't work and I have the
:>impression that nobody developing the code even cares. The method is anyways
:>obsolete in pov3.5, so the problem will disappear by itself.
: I would normally care, were it not for that "obsolete in 3.5" thing.
I should have used a ':' instead of a '.' after the word 'cares' for
clarity, because that's what I meant :)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <3B7### [at] hlavacek-partner cz>,
> anybnody knows? ;-)
My guess is that the isosurface code relies on some global variables
that aren't initialized until parsing is done...
Christopher James Huff - chr### [at] mac com, http://homepage.mac.com/chrishuff/
TAG: chr### [at] tag povray org, http://tag.povray.org/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 18 Aug 2001 05:35:42
Message: <3b7e36ee@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
This also explains why if you render the iso without the trace code, and
then add the trace code it works!
"Chris Huff" <chr### [at] mac com> ha scritto nel messaggio
news:chr### [at] netplex aussie org...
> > anybnody knows? ;-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
