POV-Ray : Newsgroups : povray.unofficial.patches : Why trace don't work with method 2 isosurfaces Server Time
28 Sep 2024 21:24:24 EDT (-0400)
  Why trace don't work with method 2 isosurfaces (Message 1 to 6 of 6)
Subject: Why trace don't work with method 2 isosurfaces
Date: 17 Aug 2001 09:18:12
Message: <3B7D1D10.4010604@hlavacek-partner.cz>
anybnody knows? ;-)
Regards
Disnel
Subject: Re: Why trace don't work with method 2 isosurfaces
Date: 17 Aug 2001 09:37:03
Message: <3b7d1dff@news.povray.org>
Disnel <dis### [at] hlavacek-partnercz> wrote:
: anybnody knows? ;-)
  I don't know the exact reason, but it just doesn't work and I have the
impression that nobody developing the code even cares. The method is anyways
obsolete in pov3.5, so the problem will disappear by itself.
Date: 17 Aug 2001 10:06:04
Message: <slrn9nq96d.djg.ron.parker@fwi.com>
I would normally care, were it not for that "obsolete in 3.5" thing.
plane{-z,-3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate
z*60#local a=a-1;#end translate-9*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{9-z*18rgb z}text{ttf"arial.ttf"
"RP".01,0translate-<.6,.4,.02>pigment{bozo}}light_source{-z*3rgb-.2}//Ron Parker
Date: 17 Aug 2001 10:12:17
Message: <3b7d2640@news.povray.org>
Ron Parker <ron### [at] povrayorg> wrote:
:>  I don't know the exact reason, but it just doesn't work and I have the
:>impression that nobody developing the code even cares. The method is anyways
:>obsolete in pov3.5, so the problem will disappear by itself.
: I would normally care, were it not for that "obsolete in 3.5" thing.
  I should have used a ':' instead of a '.' after the word 'cares' for
clarity, because that's what I meant :)
Date: 17 Aug 2001 21:17:51
Message: <chrishuff-9128A6.20140417082001@netplex.aussie.org>
In article <3B7### [at] hlavacek-partnercz>,
> anybnody knows? ;-)
My guess is that the isosurface code relies on some global variables
that aren't initialized until parsing is done...
Christopher James Huff - chr### [at] maccom, http://homepage.mac.com/chrishuff/
Date: 18 Aug 2001 05:35:42
Message: <3b7e36ee@news.povray.org>
This also explains why if you render the iso without the trace code, and
then add the trace code it works!
"Chris Huff" <chr### [at] maccom> ha scritto nel messaggio
news:chr### [at] netplexaussieorg...
> > anybnody knows? ;-)
> TAG: chr### [at] tagpovrayorg, http://tag.povray.org/
