POV-Ray : Newsgroups : povray.unofficial.patches : Mega 0.4 Transparency Bug??? Server Time
2 Nov 2024 05:19:52 EDT (-0400)
  Mega 0.4 Transparency Bug??? (Message 1 to 8 of 8)
Subject: Mega 0.4 Transparency Bug???
Date: 21 Mar 2000 12:47:13
Message: <38d7b5a1$1@news.povray.org>
Hey all,
I made a couple of images (see povray.binaries.images post of the same name)
showing an odd result of using transparency.  The first image shows a
transparent object (merge of a box and a cylinder... pigment {rgbf
<0.9,0.9,0.9,0.9>}) on a plane.  The second image is just like the first
except it uses a spotlight instead of a point light.  The problem is the
plane (and green bar) in the distance... it is much more visible as seen
thru the transparent object than it is on the sides of the image.  I
rendered it in official 3.1 and the effect was there, but to a much lesser
extent.  Is this a bug???
Eric
Subject: Re: Mega 0.4 Transparency Bug???
Date: 21 Mar 2000 15:28:57
Message: <38d7db89@news.povray.org>
"Eric Freeman" <eri### [at] datasynccom> wrote in message
news:38d7b5a1$1@news.povray.org...
The pigment was raised to 0.98 (as stated in your 2nd message at p.b.i.) and it
was okay then, am I understanding this right?  If that's all then it's a very
nearly clear texture whereas before it was not.  Anyway, it's always seemed to
me that semi-transparent textures ('transmit' especially and visible spotlights
such as through the old 'atmosphere' of v3.0*) shouldn't be brightening the
background.  But I still have not checked this against reality very well.  Now
media is easy to darken the backgrounds of visible spotlights by using
'absorption' so that's not a problem anymore.  Textures on the other hand might
still be doing this.
Date: 21 Mar 2000 15:31:07
Message: <38d7dc0b$1@news.povray.org>
I think that it's a somewhat illusionary effect but is most likely related
to gamma correction.  Some people have complained about similar 'problems'
with scattering media.  It is caused by diffuse light bouncing off of the
glass being added to the transmitted light that comes through the glass.
Also, if the description of your material does not conserve energy (if
reflected light, including diffuse, phong, etc, plus transmitted light adds
up to more than 1.0) then you could run into problems like this.
There really shouldn't be any difference between MegaPov and the official
version, though.
-Nathan
Eric Freeman <eri### [at] datasynccom> wrote...
> Hey all,
name)
> Eric
> http://www.datasync.com/~ericfree
> "I don't like it, and I'm sorry I ever had anything to do with it."
> - Erwin Schrodinger talking about Quantum Mechanics.
Date: 21 Mar 2000 19:06:07
Message: <38d80e6f$1@news.povray.org>
"Nathan Kopp" <Nat### [at] Koppcom> wrote in message
news:38d7dc0b$1@news.povray.org...
> is most likely related to gamma correction.
I think you're right.  I made a larger image and the effect was almost
unnoticable... playing with my monitor's controls helped, too.
> 'problems' with scattering media.  It is caused
> by diffuse light bouncing off of the glass being
> through the glass.
> conserve energy (if reflected light, including diffuse,
> phong, etc, plus transmitted light adds up to more
The complete texture was:
  $ GlassMat = material {
      pigment {rgbf <0.9,0.9,0.9,0.9>}
      finish {reflection 0}
reflection 0 was added after I noticed the effect to see if the visible
floor plane in the "glass" was in front of or behind the glass.  It didn't
make a difference in the image.
Eric
Date: 28 Mar 2000 12:55:48
Message: <38e0f224@news.povray.org>
I used transparency in one of my scenes and renderd it in Povray and
MegaPov. When I looked at the result I saw a only a white box in the Megapov
rendering. I shortend my scene up and here it is:
(In Povray all will remain black and in Mega box you see a white transparent
box)
camera{ location <4, 3,-6> look_at  <0, 0,  0>}
light_source
  0*x
  color rgb <1,1,1>
  spotlight
  cylinder
  translate <15,25,-15>
  point_at  <0,0,0>
  radius 200
  tightness 10
  falloff 180
box{<-1.5,-.5,1.5>, <-.5,.5,.5> pigment{color rgbt<1,1,1,.999>}}
Date: 28 Mar 2000 16:06:16
Message: <38e11ec8@news.povray.org>
Vali <val### [at] gmxat> wrote...
Megapov
This appears to be a problem with the cylinder light source in MegaPov.  The
cylinder for some reason is very overpowering, so that even when you have
0.001 effective diffuse, you will still get a lot of diffused light.  If you
comment out "cylinder" from the light source, then you will get what you
expect.
-Nathan
Date: 28 Mar 2000 21:19:06
Message: <38e1681a@news.povray.org>
In order to keep the cylindrical light source try dropping to 'tightness 5'
instead.  Why is the 'radius' larger than the 'falloff', mistake?
news:38e11ec8@news.povray.org...
| Megapov
| expect.
| -Nathan
Date: 29 Mar 2000 06:37:26
Message: <38e1eaf6@news.povray.org>
I just tested it and ...... it worked.
Nathan Kopp <Nat### [at] Koppcom> schrieb in im Newsbeitrag:
> Megapov
The
you
> expect.
> -Nathan
