POV-Ray : Newsgroups : povray.unofficial.patches : A pattern for each color component Server Time
2 Nov 2024 05:21:31 EDT (-0400)
  A pattern for each color component (Message 1 to 7 of 7)
Subject: A pattern for each color component
Date: 16 Mar 2000 04:20:56
Message: <38d0a778@news.povray.org>
How hard would it be to make a patch that allows to specify a pattern for
each color component of the pigment separately?
  I mean that the red component could have a bozo pattern, the green component
a marble pattern, the blue a granite pattern and the filter a wood pattern.
Subject: Re: A pattern for each color component
Date: 16 Mar 2000 07:09:00
Message: <chrishuff_99-874AB7.07105716032000@news.povray.org>
In article <38d0a778@news.povray.org>, Nieminen Juha
> for each color component of the pigment separately?
> component a marble pattern, the blue a granite pattern and the filter
> a wood pattern.
I think this is already possible by using 3 layered textures with
transmit and a fourth with filter. That is pretty clunky, though.
How about a new pigment_map type, "additive", which holds multiple
pigments and adds up their results, with a syntax similar to "average".
You could use one pigment for the red, another for the green, and a
third for the blue, etc.
Chris Huff
e-mail: chr### [at] yahoocom
Date: 16 Mar 2000 17:23:17
Message: <kl7ROA8DViqumXDDshn3p=K2ut20@4ax.com>
On Thu, 16 Mar 2000 07:10:57 -0500, Chris Huff
You mean like using a function pigment?
Peter Popov
pet### [at] usanet
ICQ: 15002700
Date: 16 Mar 2000 17:40:02
Message: <chrishuff_99-E70073.17415916032000@news.povray.org>
In article <kl7ROA8DViqumXDDshn3p=K2ut20@4ax.com>, Peter Popov
No, like using an average pigment.
4.7.7.2  Average
Technically average  is not a pattern type but it is listed here
because the syntax is similar to other patterns. Typically a pattern
type specifies how colors or normals are chosen from a pigment_map ?
texture_map , density_map , or normal_map , however average  tells
POV-Ray to average together all of the patterns you specify.  Average
was originally designed to be used in a normal statement with a
normal_map  as a method of specifying more than one normal pattern on
the same surface. However average may be used in a pigment statement
with a pigment_map  or in a texture statement with a texture_map  or
media density with density_map  to average colors too.
For example
    average
    pigment_map {
      [1.0  Pigment_1]
      [2.0  Pigment_2]
      [0.5  Pigment_3]
An "additive" pattern would add the colors/densities/normals/whatever
together instead of averaging them together. You could subtract a
"channel" by using negative numbers for it. Maybe "multiplicative" would
also be good.
It would also be nice to be able to specify the way they are combined by
using an isosurface function, but I don't know how this would be
specified with the current syntax or how difficult it would be to
implement.
Chris Huff
Date: 17 Mar 2000 02:46:27
Message: <uuHROAdW7u43Bf5Adcmh+NsBeW1d@4ax.com>
On Thu, 16 Mar 2000 17:41:59 -0500, Chris Huff
>also be good.
>implement.
#declare R_Bozo=function{pigment{bozo{color_map{[0 Red][1 Black}}}
#declare B_Wood=function{pigment{wood{color_map{[0 Blue][1 Black}}}
#declare G_Agate=function{pigment{agate{color_map{[0 Green][1 Black}}}
sphere
{0,1 pigment{function{R_Bozo(x,y,z)+B_Wood(x,y,z)+G_Agata(x,y,z)}}}
Sorry_my_space_bar_died_gotta_fix_it
Peter Popov
pet### [at] usanet
ICQ: 15002700
Date: 17 Mar 2000 02:58:34
Message: <38D1E9DC.1E3BA88E@nanterre.marelli.fr>
> sphere
I think that this doesn't work for the effect Warp is looking for...
Try something like this:
#declare R_Bozo=pigment{bozo{color_map{[0 Red*3][1 Black}}
#declare B_Wood=pigment{wood{color_map{[0 Blue*3][1 Black}}
#declare G_Agate=pigment{agate{color_map{[0 Green*3][1 Black}}
sphere
{0,1 pigment{
	average
	pigment_map {
		[1 R_Bozo]
		[1 B_Wood]
		[1 G_Agate]
But there is no solution for the filter (or transmit) channel...
Bouf.
Date: 17 Mar 2000 08:31:01
Message: <38D2339D.62E810AF@atos-group.com>
> also be good.
And a mininal as well as a maximal (component by component,
so minimal of Red and Blue leave Black, and
maximal of Yellow and Blue leave White...)
