POV-Ray : Newsgroups : povray.unofficial.patches : Feature question: exporting Server Time
29 Sep 2024 21:22:23 EDT (-0400)
  Feature question: exporting (Message 1 to 9 of 9)
Subject: Feature question: exporting
Date: 16 Feb 2000 10:15:29
Message: <38AABE2B.42EAB160@my-dejanews.com>
Will pov ever be able to export pov-derived object?  Say, export a pov
blob or pov isosurface to dxf or mesh?
Subject: Re: Feature question: exporting
Date: 16 Feb 2000 11:42:23
Message: <38AACF8B.7A15FB26@pacbell.net>
It is possible that it might but not at any time in the near future.
In case you have missed the many conversations on this in the past
the reason it is not currently possible is because POV-Ray's objects
are internaly represented mathematicaly rather than as constructs of
triangles such as is found in most modelling systems. To be able to
export to .dxf or other 3D file formats a serious amount of work will
have to be done to tesselate each POV-Ray primitive into triangles.
NOT an easy thing to do and almost impossible for some primitives like
the infinite poly, quadric, and quartic objects.
Date: 16 Feb 2000 15:13:36
Message: <38AB03F3.3C1F0B5C@my-dejanews.com>
Understood.
It probably could be done, to some extent, with a pov scene itself, using
#write, max/min_extent, and trace functions.  May try it someday. Thanks for
the lesson.
> Ken Tyler -  1300+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Date: 17 Feb 2000 05:19:03
Message: <38abcb17@news.povray.org>
Note also that exporting to other formats is usually a task of the
modeller, not the renderer. Povray is a renderer.
Date: 17 Feb 2000 09:24:53
Message: <38AC03CB.1268A098@my-dejanews.com>
Speak for yourself!  Can Moray do isosurfaces?
Date: 22 Feb 2000 05:32:45
Message: <38B265C8.9EEB43CE@chl.chalmers.se>
I made a test patch sometime last year to make meshes from blobs and
render wich could easily be expanded to include isosurfaces and
exporting of the triangles.
The patch uses a method similar to marching cubes, but it uses
tetrahedrons instead.
Anyway, if you can code some I can send you the changes made to the
povray source so you can make your own exporter.
/Anders
Date: 22 Feb 2000 09:05:56
Message: <38B296D4.1F5E616D@my-dejanews.com>
Povray is the only programming language I am currently fluent in.  Was it in
pov?
> /Anders
Date: 22 Feb 2000 16:38:32
Message: <chrishuff_99-EF6661.16395422022000@news.povray.org>
In article <38B265C8.9EEB43CE@chl.chalmers.se>, Anders Haglund
This sounds interesting, maybe you could post the source here. I think
isoblobs could also benefit from this...
Chris Huff
e-mail: chr### [at] yahoocom
Date: 3 Jun 2000 15:22:32
Message: <39395af8@news.povray.org>
It's Doable with MegaPOV and Charles Fusner's TriScan
Macro(http://www.silvertome.com/packages/triscan.html).  It exports objects
to either RAW, whcih can be easily converted to DXF and other formats, or
LSL, whcih is used as a reference shape in Leveller.
