POV-Ray : Newsgroups : povray.unofficial.patches : More SUGGESTIONS :-) Server Time
29 Sep 2024 21:23:51 EDT (-0400)
  More SUGGESTIONS :-) (Message 1 to 10 of 15)
Subject: More SUGGESTIONS :-)
Date: 15 Feb 2000 18:42:06
Message: <38A9E46C.15E808B6@alpharay.de>
In my opinion, two VERY USEFUL features:
- no anti-alias against background
    -> to render sprites, buttons, etc.
- reflection-map
    -> the current reflections are to perfect. Current scenes seems much
to clean!
    A reflection-map can be used to simulate a dirty floors (marble,
wood), streets after rain, etc.
    Syntax (suggestion):
        finish {
                    reflection_map {
                                spotted
                                turbulence 0.2
                                [ 0.0 0.1 ]        -> 20 % reflection
                                [ 0.8 0.2 ]
                                [ 1.0 0.6 ]        -> 50 % reflection
Bye
 Paul
Subject: Re: More SUGGESTIONS :-)
Date: 15 Feb 2000 19:52:58
Message: <chrishuff_99-206239.19540915022000@news.povray.org>
In article <38A9E46C.15E808B6@alpharay.de>, Paul Blaszczyk
Maybe a good idea...
> - reflection-map
> to clean!
I think finish_map would be a more flexible and general solution to this
problem. Or the other extreme: maybe have every texture attribute now
controlled with a float controlleable by an isosurface-type function. :-)
And everything that accepts a color should accept a pigment too...yes,
it is insane...
Although I have been thinking of adding the ability to use a pigment as
a light_source color. It would have two different modes: the usual
pigment calculation method, where the color of the light at a point is
the same as the pigment at that point, and a depth based calculation
method, which would use the length the ray has travelled as the z
distance when evaluating the pigment(good for wave simulations?).
This would be pretty easy to do, I just haven't had the time...
Chris Huff
e-mail: chr### [at] yahoocom
Date: 15 Feb 2000 20:24:41
Message: <38a9fc59@news.povray.org>
Patterned and color-mapped light sources?  Fine with me :-)
I can already imagine translating a pigment pattern in a light source and
shifting colors that way or seeing the effect of near light speed travel or
something, etcetera.
But now I've understood what you were saying.  Too bad, oh well, no loss if it
doesn't yet exist anyway.
"Chris Huff" <chr### [at] yahoocom> wrote in message
news:chrishuff_99-206239.19540915022000@news.povray.org...
Date: 16 Feb 2000 05:38:19
Message: <38aa7e1b@news.povray.org>
Paul Blaszczyk <3d### [at] alpharayde> wrote:
: - no anti-alias against background
:     -> to render sprites, buttons, etc.
  A more general approach:
  Add a new keyword, eg. 'no_antialiasing'. When applied to an object, then
a ray hitting this object will stop the supersampling immediately. Should
be easy to implement.
: - reflection-map
:     -> the current reflections are to perfect. Current scenes seems much
: to clean!
  Wouldn't blurred reflection just do it?
Date: 16 Feb 2000 07:09:36
Message: <chrishuff_99-07DCE8.07104816022000@news.povray.org>
In article <38aa7e1b@news.povray.org>, Nieminen Juha
<war### [at] sarakerttunencstutfi> wrote:
> : - reflection-map
> :     much
> : to clean!
I believe what he wants is a way to vary the amount of reflection
according to a pattern without having to use a texture_map. A finish_map
should be sufficient for this, though...
Chris Huff
Date: 16 Feb 2000 08:55:44
Message: <38aaac60@news.povray.org>
Nieminen Juha <war### [at] sarakerttunencstutfi> wrote...
then
This could end up more complicated than you might think.
First, radiosity sampling methods generally re-use points from one pixel
calculation to the next.  This would probably not be a problem, though (I
think POV implements something like a dirty-pixel buffer that determines if
it needs to trace the sample or not).
Second, what do you do if you can see an object _through_ another object.
What if the clear blocking object is a crystal?  What if it is, instead, a
media container object?  I have been wondering how to handle this and
similar questions when dealing with post-processing.  There will be ways to
tag objects for post processing, and then let the filter find out if a
tagged object was hit.  But how should those clear media containers be
handled???  And what about not-so-perfectly-clear, yet mostly clear,
objects, like a wine glass.  The other thing to worry about for me is depth.
Which depth should be returned: the first object hit, or the first object
that you'd actually _see_?
-Nathan
Date: 16 Feb 2000 21:06:21
Message: <dlarOOn7DOAwGbFmT3EXtO5xPFY+@4ax.com>
On Wed, 16 Feb 2000 00:42:37 +0100, Paul Blaszczyk <3d### [at] alpharayde>
Render your scene. Save the image.
Add these options to the command line:
+q0 +ua -d -a
Render and save again. Now use the alpha channel from the second image
with the first image and you have an anti-aliased sprite.
Peter Popov
pet### [at] tagpovrayorg
ICQ: 15002700
Date: 17 Feb 2000 05:16:04
Message: <38abca64@news.povray.org>
Nathan Kopp <Nat### [at] koppcom> wrote:
: Second, what do you do if you can see an object _through_ another object.
  Well, I think that it could be implemented anyways. The documentation could
state that "this feature may not work well with transparent objects" or
something like that.
  After all, this feature will likely to be used in situations where the
non-antialiased object is directly seen from the camera (like sky spheres
with granite pigment simulating a starfield, etc).
  And if media is not antialiased (because there's a starry sky behind it),
does it matter? AFAIK media doesn't need antialiasing.
Date: 17 Feb 2000 05:48:10
Message: <chrishuff_99-3AE5EA.05492317022000@news.povray.org>
In article <38abca64@news.povray.org>, Nieminen Juha
> : object.
>   could
>   it),
One solution would be to trace one ray, if it hits an object, check that
object for a flag that tells whether or not to supersample it, and fire
additional samples based on that information. This would be done at each
level. It should work correctly with transparency and media, although it
should probably be turned off when "global" anti-aliasing is turned on.
Chris Huff
Date: 17 Feb 2000 07:18:18
Message: <38ABE691.7B1FF976@alpharay.de>
> +q0 +ua -d -a
Good idea...for one button or sprite. But what is with animated sprites
(with MUCH frames)? (e.g. for a game... 100 frames per figure and 10
figures in game).
Paul
