POV-Ray : Newsgroups : povray.unofficial.patches : Crash with trace() and mesh Server Time
2 Nov 2024 03:15:23 EDT (-0400)
  Crash with trace() and mesh (Message 1 to 6 of 6)
Subject: Crash with trace() and mesh
Date: 3 Feb 2000 19:34:17
Message: <389A1F36.A4DD8872@peak.edu.ee>
Using the trace() function with either mesh or mesh2 causes my copy of
WinMegaPov 0.4 to exit with an illegal operation. Same happens with the
SuperPatch 3.1e (Windows version). Must an old problem, but somehow I've missed
it until now.
Neither individual triangles nor unions of triangles are affected.
Margus
Subject: Re: Crash with trace() and mesh
Date: 6 Feb 2000 20:56:22
Message: <389e2646@news.povray.org>
Yes, the mesh queue was not initialized before the parse.  This same problem
happened with blobs, too.  It will be fixed in the next version.
-Nathan
Margus Ramst <mar### [at] peakeduee> wrote...
missed
> it until now.
> Margus
Date: 6 Feb 2000 21:42:51
Message: <slrn89sc1f.v8.ron.parker@parkerr.fwi.com>
I know I fixed that once. Did it somehow not make it into the version
I put online?
These are my opinions.  I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
Date: 6 Feb 2000 22:59:33
Message: <389e4325@news.povray.org>
In your posted version the blob queue was fixed, but the mesh queue was not.
BTW, is it a good idea to leave initialize the queue before parsing and
leave it that way after the trace() function is called?  Might it be a good
idea to reset it between parsing and rendering and even between successive
calls to trace()?
Instead of calling Initialize_xxx_Code before parse, it would probably be
better to call Initialize_xxx_Code before calling Intersection within
Parse_Trace and then calling Deinitialize_xxx_Code after that call to
Intersection and finally calling Initialize_xxx_Code between parsing and
rendering.
-Nathan
Ron Parker <ron### [at] povrayorg> wrote in message
news:slr### [at] parkerrfwicom...
problem
> I put online?
Date: 7 Feb 2000 08:10:42
Message: <389ec452@news.povray.org>
Oddly enough, my local version is that way too.  It must have been one of
the changes I lost when my HD died.
>calls to trace()?
Does it do that when you render a real scene?  If so, then yes.  If not,
there's probably no harm in initializing it early.  Personally, I can't find
anywhere that it gets initialized other than that first call, so I'd guess
it's fine the way it is.
Date: 7 Feb 2000 09:30:30
Message: <389ed706@news.povray.org>
Ron Parker <ron### [at] povrayorg> wrote...
good
successive
> >calls to trace()?
find
I took a closer look at the queue and it doesn't cache any data between
successive calls to Intersect, so it is OK the way it is and the
reinitialization is not necessary.
-Nathan
