POV-Ray : Newsgroups : povray.unofficial.patches : MEGAPov error in mesh differences Server Time
23 Mar 2026 13:12:10 EDT (-0400)
  MEGAPov error in mesh differences (Message 1 to 10 of 12)
Subject: MEGAPov error in mesh differences
Date: 12 Jan 2000 16:39:54
Message: <387cf4aa@news.povray.org>
All of my aircraft models have been affected by something in MegaPov. I use
a lot of differences in order to apply images to given portions of the
planes, clip out panels, etc., and I keep seeing extraneous portions of the
difference object.
To test this I took a simple sphere mesh, and subtracted out a  box
(non-mesh). A portion of the box remains within the scene. I could post the
code, but I am sure you can reproduce this. I will post sample images, if
you request it (to binaries.images, of course).
GrimDude
gri### [at] isonet
Subject: Re: MEGAPov error in mesh differences
Date: 13 Jan 2000 20:32:34
Message: <387E719E.D7223362@enter.net>
> difference object.
Are you saying these models worked in official POV? Because by
rights they probably shouldn't have. Meshes never used to be
reliably usable for CSG other than unions because they had no
well defined insides and outsides, and if differencing other
shapes from them worked at all, it proabably acted like clipping.
MegaPOV changed this by giving meshes "insides" so differencing
from a mesh will behave in a fundamentally different way in
MegaPOV, but that most likely isn't a bug you're seeing. You
might have to substitute clipped_by for difference to get the
same effect now.
Is it fundamentally different from when you do the same difference
of a box from a regular sphere primitive? If not, what you're
seeing is the difference "solid" meshes (new in MegaPOV) makes
on the operation.
Charles
Date: 14 Jan 2000 00:43:56
Message: <387eb79c@news.povray.org>
Nope.
I have used this technique since the introduction of the mesh object.
#declare Ball = mesh { smooth_triangle.... }
difference {
   object { Ball }
   object { box ... } }
This worked in the official release, in SuperPov, but not with MegaPov. :(
Actually, it still works. There are, however, extraneous objects showing up.
GrimDude
gri### [at] isonet
Date: 14 Jan 2000 06:05:59
Message: <387f0317@news.povray.org>
What happens if you use 'inverse' for either the Ball or the box or the
difference itself.
"GrimDude" <gri### [at] netfreecom> wrote in message
news:387eb79c@news.povray.org...
> Nope.
> difference {
>    object { Ball }
> GrimDude
> gri### [at] isonet
Date: 14 Jan 2000 08:28:27
Message: <387f247b@news.povray.org>
On Thu, 13 Jan 2000 23:43:50 -0600, GrimDude wrote:
>Nope.
>difference {
>   object { Ball }
It shouldn't work in any of them, with the possible exception of MegaPOV.
Parts of the box that are properly inside the ball should still show up.
If it did work, it was a lucky coincidence.
These are my opinions.  I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
Date: 14 Jan 2000 08:29:48
Message: <387f24cc@news.povray.org>
>>Nope.
>>difference {
>>   object { Ball }
er... s/inside/outside/, if you would.
Date: 14 Jan 2000 15:59:53
Message: <387F5B24.7EA4BE13@bahnhof.se>
No no no.. Compile it and make a binary statemachine out of the regexp, apply to
the. . . . .
(I've been around a comp.sci. stud for far too long... he got me hooked :p )
//Spider    --  [ spider@bahnhof.se ]-[ http://darkmere.wanfear.com/ ]
And the devil in black dress watches over
    My guardian angel walks away
Life is short and love is always over in the morning
    Black wind come carry me far away
            --"Sisters of Mercy" -- "Temple Of Love"
Date: 15 Jan 2000 01:52:05
Message: <38801915@news.povray.org>
Well, so far I've come across more then 2000 lucky coincidences. :)
I worked alright. Everytime too. I know, I was warned my Ron Parker (and
Chris Colefax, too, who both recommended clipping years ago I think), that
it wasn't proper coding and shouldn't work. But, it did, so I continued the
practice. The worst part is, after I got all of the independant portions
coded I merged it with the overall code, so now I have a real mess!
Ah, well! Clipping (w/wo inverse) fixes it.
GrimDude
gri### [at] isonet
Date: 15 Jan 2000 02:01:12
Message: <38801b38@news.povray.org>
The same extraneous portion shows up, but with the disected section rather
then the
host.
GrimDude
gri### [at] isonet
omniVERSE <inv### [at] aolcom> wrote in message
news:387f0317@news.povray.org...
> difference itself.
> Bob
> > Nope.
> > difference {
> >    object { Ball }
up.
> > GrimDude
> > gri### [at] isonet
Date: 15 Jan 2000 04:14:11
Message: <38803a63@news.povray.org>
Is there a texture (pigment at least) on the differencing object (box in this
case)?  Reason I ask is that I had a similar sounding situation a couple years
ago.
news:38801b38@news.povray.org...
> then the
> host.
