POV-Ray : Newsgroups : povray.unofficial.patches : Question about isosurface functions Server Time
19 Nov 2025 22:49:58 EST (-0500)
  Question about isosurface functions (Message 1 to 10 of 12)
Subject: Question about isosurface functions
Date: 4 Jan 2000 12:07:58
Message: <387228ee@news.povray.org>
If this gives me a sphere:
isosurface { function { x^2+y^2+z^2-1 } }
why this doesn't:
#declare f1 = function { x }
#declare f2 = function { y }
#declare f3 = function { z }
isosurface { function { f1^2+f2^2+f3^2-1 } }
Subject: Re: Question about isosurface functions
Date: 4 Jan 2000 12:29:32
Message: <chrishuff_99-6D76A9.12293704012000@news.povray.org>
In article <387228ee@news.povray.org>, Nieminen Juha
> why this doesn't:
I think there might be a bug with the isosurface functions when the
parameters are not specified. I think it should use (x, y, z) by
default, but this crashed MacMegaPOV when I tried it. Try using:
isosurface {
    function {
        f1(x, y, z)^2+
        f2(x, y, z)^2+
        f3(x, y, z)^2-1
instead.
Chris Huff
e-mail: chr### [at] yahoocom
Date: 4 Jan 2000 12:37:44
Message: <38722fe8@news.povray.org>
Chris Huff <chr### [at] yahoocom> wrote:
: I think there might be a bug with the isosurface functions when the
: parameters are not specified. I think it should use (x, y, z) by
: default, but this crashed MacMegaPOV when I tried it. Try using:
: isosurface {
:     function {
:         f1(x, y, z)^2+
:         f2(x, y, z)^2+
:         f3(x, y, z)^2-1
: instead.
  It didn't help.
Date: 4 Jan 2000 13:20:15
Message: <chrishuff_99-6C6FA0.13202004012000@news.povray.org>
In article <38722fe8@news.povray.org>, Nieminen Juha
>   It didn't help.
Hmm, I don't know what's wrong. I tried a few things for myself, and
while it crashes when noise3d is used with no parameters, those
functions render with no trouble...but with no result. Also, these
doesn't work:
#declare f4 = function {x^2+y^2+z^2}
isosurface {function {f4(x, y, z)-1}}
#declare f4 = function {sqrt(x^2+y^2+z^2)}
isosurface {function {f4(x, y, z)^2-1}}
but these do:
isosurface {function {sqrt(f4(x, y, z))-1}}
However, if you force method 1 solving, everything seems to work fine.
Just add the line "method 1" to the isosurface. Of course, this slows
things down.
Specifying a larger max_gradient(I tried 5) seems to work too. I would
guess maybe it is having trouble calculating the gradient of those
declared functions.
Chris Huff
Date: 4 Jan 2000 13:33:02
Message: <38723C50.47FAFFCE@tapestry.tucson.az.us>
I'm afraid that I can't help you with you question, but I have another
similar question:
Why does y-exp(-(x^2)-(z^2)) render the same as y-exp(-(x^2)-z^2) but
differently from y-exp(-x^2-(z^2)) and y-exp(-x^2-z^2)?
Date: 4 Jan 2000 14:26:23
Message: <3872495f@news.povray.org>
Order of math, the non-parenthesis parts will go last.
"Kevin Wampler" <kev### [at] tapestrytucsonazus> wrote in message
news:38723C50.47FAFFCE@tapestry.tucson.az.us...
> similar question:
Date: 4 Jan 2000 15:07:02
Message: <387252e6@news.povray.org>
>similar question:
Without looking at the code, it looks like it's using too high a priority
for unary minus, so it's treating "-x^2" as "(-x)^2".  BTW, I suspect you'd
get better performance with the sqr() function.
These are my opinions.  I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
Date: 4 Jan 2000 15:19:18
Message: <38725525.57F20A09@tapestry.tucson.az.us>
That's what I thought, but upon closer examination, it appears to only assign
the unary minus a higher priority on the first term, so y-exp(-x^2-z^2)
renders differently from y-exp(-z^2-x^2).  Good point about the sqr()
function, I hadn't realized that it was optimized.
Date: 4 Jan 2000 15:32:13
Message: <387258cd@news.povray.org>
The second term isn't a unary minus; it's the binary subtraction operator.
Date: 4 Jan 2000 15:40:32
Message: <38725A26.AABDB462@tapestry.tucson.az.us>
<voice = Homer> doh! </voice>
