POV-Ray : Newsgroups : povray.unofficial.patches : MegaPov bug - isosurfaces Server Time
23 Mar 2026 15:03:06 EDT (-0400)
  MegaPov bug - isosurfaces (Message 1 to 4 of 4)
Subject: MegaPov bug - isosurfaces
Date: 11 Dec 1999 15:22:58
Message: <3852B45C.5570F4AA@aol.com>
I found a bug in MegaPov which has to do with #declared function
pigments used in isosurfaces. It gave me an error, "cannot load
function." I wanted to test the sped-up crackle and found the bug as a
result. Here's the code:
#declare Tex = function{ pigment{ crackle color_map{ [0 rgb 1][1 rgb 0]
isosurface{
 function
  ( x^2+y^2+z^2 )+( Tex( x,y,z )/4 )
 threshold 1 sign 1
 accuracy .005 max_gradient 10
 pigment{ rgb 1 } finish{ phong 1 }
Samuel Benge
E-Mail: STB### [at] aolcom
Visit the still unfinished isosurface tutorial:
http://members.aol.com/stbenge
Subject: Re: MegaPov bug - isosurfaces
Date: 11 Dec 1999 16:36:44
Message: <3852C3B2.E46792B7@pacbell.net>
I ran into several demo's with the same problem. Also the iso demos that
had the 'library" function in the statement would not work at all.
Ken Tyler -  1200+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Date: 11 Dec 1999 18:38:47
Message: <3852E23D.AEE944B1@aol.com>
I tried to use a function as a pigment, too, and it did not work. I even
tried putting it directly into the pigment statement, not declaring it, but
it still won't work. It doesn't seem to reconize the word 'function'.
Samuel Benge
Date: 12 Dec 1999 04:54:13
Message: <1e2oxuq.1mm3vxg1gk7y70N%smellenbergh@skynet.be>
SamuelT. <STB### [at] aolcom> wrote:
Tried it and they do work. However, there was a switch missing in
Nathan's frame.h. Perhaps it wasn't there when he uploaded version 0.1.
Anyway, in the next version this will work, just tried your example.
We also fixed the library problem for the isosurface. You can now use:
    function  {  "func_13", <5.5>,  library "i_nfunc" }
or
    function  {  "func_13", <5.5> }
External libs are not supported in the MegaPov but most of them are
build in.
There is one library we didn't add yet: i_dat3d. That one needs
initialisation. An error will be given.
Perhaps it would be better if we remove those example scenes (i_3d_o.pov
and i_3d_o2.pov)
Smellenbergh
> > http://home.pacbell.net/tylereng/index.html http://www.povray.org/links/
> Samuel Benge
e-mail:sme### [at] skynetbe
http://users.skynet.be/smellenbergh
