POV-Ray : Newsgroups : povray.unofficial.patches : Mipmapping and trilinear filtering in povray Server Time
17 Jul 2026 18:23:20 EDT (-0400)
  Mipmapping and trilinear filtering in povray (Message 7 to 16 of 16)
<<< Previous 6 Messages Goto Initial 10 Messages
Subject: Re: Mipmapping and trilinear filtering in povray
Date: 10 Nov 1999 09:15:33
Message: <38297e05@news.povray.org>
TonyB <ben### [at] panamaphoenixnet> wrote:
: Go ahead, please, by all means, add it...
  Actually my article was a request for someone else to do it... :)
Date: 10 Nov 1999 10:36:37
Message: <38299105@news.povray.org>
Did you check out the link? It's pretty cool. Gamasutra is a great site,
they manage to reduce the computations from 3978 adds and 8586 multiplies to
1506 adds and 1488 multiplies. I have no idea how useful this would be to
POV-Ray, however. I also found out where the Nintendo developers go to. =)
Date: 10 Nov 1999 15:22:07
Message: <3829d3ef@news.povray.org>
In article <382### [at] 194174214110> , lut### [at] stmuccom (Lutz
Kretzschmar) wrote:
>> Hmm, distance based recursive anti-aliasing should solve this problem -
>> determine the recursion level by the distance of the intersection.
> That is computationally much too expensive. Since the antialiasing has
> already been done by making a mipmap, it is not neccessary to fire
> extra rays. And once you start getting far away you would have to
> antialias far too many rays.
Yes, just for imagemaps. But that wasn't my point; it simply is a primitive
method that works with procedural textures as well.
My suggestion does of course not eliminate 'the missing a small object (or
texture detail) problem', it would only reduce it  by forcing a certain
recursion level depending on the distance (rather than only the threshold).
However, it is not difficult to construct a case (i.e. with a checker
pattern) that would easily break it - like all (recursive) antialiasing
based methods.
    thorsten
e-mail: tho### [at] trfde
Date: 10 Nov 1999 15:25:14
Message: <3829d4aa@news.povray.org>
In article <3828efdc@news.povray.org> , "Nathan Kopp" <Nat### [at] Koppcom>
wrote:
> Unfortunately, anti-aliasing won't always fix the problem.  The primary
> difference is that with mipmapping, as the camera moves farther and farther
> away, more and more pixels are effectively averaged to produce the final
> output.  At the first stage, you get 4 pixels (2x2) averaged into 1.  The
> next stage might be 2x2 blocks of stage 1, meaning 4x4 of the original or 16
> total pixels.  By the time you get to stage three, its 2x2 of stage 2, or
> 8x8 of the original, or 64 pixles.  Getting that good of results by POV's
> current anti-aliasing techniques would really make things slow.
Hmm, for now a workaround migth be to use an external program to scale down
the image and use that as image map. Not a great workaround I have to admit,
but it will work (if Nieminen needs a workaround right now).
   Thorsten
Date: 11 Nov 1999 01:06:49
Message: <382A6C59.859BDE67@mailbag.com>
I discovered it several months ago.  It truly is a valuable resource on
several topics in graphics programming.
-Mark Gordon
Date: 11 Nov 1999 04:41:39
Message: <382a8f53@news.povray.org>
Thorsten Froehlich <tho### [at] trfde> wrote:
: Hmm, for now a workaround migth be to use an external program to scale down
: the image and use that as image map. Not a great workaround I have to admit,
: but it will work (if Nieminen needs a workaround right now).
  But then the image map will not be detailed near the camera.
  And no, it's not a problem I'm currently having. It's just an idea.
Date: 23 Nov 1999 10:21:21
Message: <DrA6OAL+NDTeJAu6xWX1Bjs=49U2@4ax.com>
On 9 Nov 1999 07:43:37 -0500, Nieminen Juha
<war### [at] punarastascstutfi> wrote:
>  Now, povray only supports bilinear filtering. How about adding automatic
>mipmapping and trilinear filtering to it?
What about implementing bicubic interpolation, similiar to Photoshop?
That program seems to resize images very well.
Date: 23 Nov 1999 17:31:52
Message: <qRU7OBn+TGxYExBveXK6y4gj6swI@4ax.com>
On Tue, 23 Nov 1999 10:20:59 -0500, Glen Berry <7no### [at] ezwvcom>
Bicubic interpolation is supported by POV. Check out "bitmap
modifiers" in the docs.
Peter Popov
ICQ: 15002700
Date: 24 Nov 1999 02:49:43
Message: <wb903oba6t.fsf@infostream.no>
[On 9 Nov 1999 07:43:37 -0500, Nieminen Juha <war### [at] punarastascstutfi>]
|   However, when the texels are smaller than the screen pixels, the bilinear
| interpolation doesn't help much.
True, that's why we have antialiasing.
| like broken lines, moire patterns, etc (even when antialiasing in on)
Not if used correctly. You should try the adaptive supersampling.
|   In most 3D engines (renderers, 3D games, 3D video cards...) this problem
| is corrected by calculating mipmapping and trilinear filtering.
True. But the reason they do this is because it's more convenient than
proper antialiasing like the one we have in POV-Ray, and it's easy to
implement in hardware. Also, trilinear filtering bring on other visual
artifacts. For instance, resolution drops in both directions when a
texture is viewed at an angle. Hardware tries to cope with this by
introducing so called anisotropic filtering, but that also has it's
limits.
In POV-Ray, supersampling can be used to correct any aliasingproblems
you may have, and it will work on any texture, not just image maps.
| The result is very good.
It pales in comparison with proper supersampling.
A penny for your thoughts.
Mine are more expensive.
Date: 24 Nov 1999 08:07:20
Message: <383be308@news.povray.org>
Not really.  Textures should antialias themselves based on the "size" of
the ray hitting them, as well, if you want to avoid certain kinds of aliasing.
These are my opinions.  I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
