POV-Ray : Newsgroups : povray.unofficial.patches : Question on isosurfaces Server Time
20 Nov 2025 03:20:28 EST (-0500)
  Question on isosurfaces (Message 1 to 4 of 4)
Subject: Question on isosurfaces
Date: 2 Sep 1999 11:08:21
Message: <37ce92e5@news.povray.org>
Can anyone tell me how the built in isosurface function helix1
works. I tried
isosurface {
 function { "helix1" <2,1,0.2,1,0,1,0> }
 threshold 1
 sign 1
 pigment {Red}
but just got a cylinder.
Any help will be appreciated.
Thanks
Gail
* gsh### [at] monotixcoza              * ERROR: COFFEE.COM not found  *
* http://www.rucus.ru.ac.za/~gail/ * Insert cup and press any key *
   My Software never has bugs, It just develops random features
Subject: Re: Question on isosurfaces
Date: 2 Sep 1999 11:30:27
Message: <37ce9813@news.povray.org>
>works. I tried
>isosurface {
> threshold 1
> sign 1
> pigment {Red}
Try this:
isosurface {
 function { "helix1" <2,1,0.2,1,1,1,0> }
 threshold 0
 max_gradient 20 method 2
 bounded_by {box {-10,10}}
 sign 1
 pigment {red 1} finish {ambient .4}
Most of the internal functions are designed to work with a threshold of
zero.  By default, they're bounded by a small box, so you need to add a
bounding volume if you want to see anything interesting.  I also added
the max_gradient 20 method 2 to eliminate some gaps in the result.
Finally, the docs for parameter 4 ("shape parameter") are useless, but
a little playing shows that it is the ratio of height to width for the
ellipses the "strands" are made out of.  Zero is a bad number, and will
in fact crash on some architectures.  Replacing it with a one gives
you a circular cross-section, which is what I assume you wanted.  I'll
try to remember to fix this in the next version of the docs.
Date: 3 Sep 1999 02:25:49
Message: <37cf69ed@news.povray.org>
Ron Parker wrote in message <37ce9813@news.povray.org>...
>Try this:
>isosurface {
> threshold 0
> sign 1
Thanks, that's basically what I wanted.
Next question. Can I use the isosurface functions within media.
I seem to vaguely remember a discussion on that, can't remember when or
where
though
Thanks
Gail
Date: 3 Sep 1999 11:33:48
Message: <37CFEA9E.38790EC2@compuserve.com>
Yes, they can be used in media, or in place of any other pattern. Just
use function {function stuff here} in place of the pattern name.
