POV-Ray : Newsgroups : povray.unofficial.patches : Trouble compiling Superpatch for Mac Server Time
23 Mar 2026 18:39:07 EDT (-0400)
  Trouble compiling Superpatch for Mac (Message 1 to 9 of 9)
Subject: Trouble compiling Superpatch for Mac
Date: 1 Oct 1999 09:30:18
Message: <37F4B7D5.5791FEBA@compuserve.com>
I have finally gotten the Superpatch to compile properly, but if I use
an isosurface in a scene, it crashes after completing the render. It
generates the correct image file, but then drops into MacsBug and gives
this error:
PowerPC unmapped memory exception at 0D2EF480 remove_node+0000C
Any suggestions on where to look for the problem? I am fairly certain it
is in one of the isosurface files, because it seems to only happen when
they are used.
Subject: Re: Trouble compiling Superpatch for Mac
Date: 1 Oct 1999 09:39:04
Message: <37F4B9E3.A343BF61@compuserve.com>
That is an older version of the isosurface patch and an older version of
POV(3.02a). POV-Ray Unofficial(http://users.skynet.be/smellenbergh/) is
much more current-but still doesn't have all of what I need.
Date: 1 Oct 1999 09:40:19
Message: <37f4b9c3@news.povray.org>
>this error:
>they are used.
This happens for all isosurfaces, or for a specific scene?  Is it a
#declared object or is it specified directly?
Date: 1 Oct 1999 09:42:06
Message: <37F4BA99.CFD6ED86@compuserve.com>
It is specified directly, and I haven't tested it enough to tell if it
happens for every isosurface. It happens for every one I have tried,
though(which is only a few).
Date: 1 Oct 1999 09:43:16
Message: <37F4BA07.9EADDEFB@pacbell.net>
For some reason I had that described as a POV-Ray v3.1 version. This
has been corrected and I am sorry for wasting your time with it.
Ken Tyler
1100+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Date: 1 Oct 1999 09:49:17
Message: <37f4bbdd@news.povray.org>
Do you have a source-level debugger so you can give me a stack traceback
along with source code for the three or four lines around each entry in
the stack?
Date: 1 Oct 1999 21:11:28
Message: <37F55C2B.1C8B4F5E@compuserve.com>
Well, the problem appears to be in the function Destroy_Function() in
F_FUNC.C. The crash does not occur if the POV_FREE() calls are commented
out, I will be working on narrowing it down further.
Oh, I do have a fairly advanced debugger, but I don't know how to use it
well. Is this something like what you were looking for?
  03A0CA80    PPC  0D2F06FC  Terminate_POV+00014
  03A0CA40    PPC  0D2F0864  close_all+000F8
  03A0CA00    PPC  0D2F2178  Destroy_All_Functions+0002C
  03A0C9C0    PPC  0D2F2254  Destroy_Function+00090
Date: 1 Oct 1999 21:20:26
Message: <37F55E46.74466B72@compuserve.com>
Ok, I narrowed it down to the line
      if (Func->pnum >0) POV_FREE (Func->parm);
in Destroy_Function. If this line is commented out, the error doesn't
appear.
I think commenting this out causes a memory leak, however, the error
might be appearing because this has already been freed. I will be
studying the code some more, and running more tests...
Date: 2 Oct 1999 10:11:06
Message: <slrn7vbjg7.3su.parkerr@linux.parkerr.fwi.com>
>appear.
It might also be appearing because under some unknown circumstances it
didn't get allocated, but I haven't gotten a chance to look at the code
yet to see if that's the case.
