Can anyone tell me how the built in isosurface function helix1
works. I tried
isosurface {
function { "helix1" <2,1,0.2,1,0,1,0> }
threshold 1
sign 1
pigment {Red}
but just got a cylinder.
Any help will be appreciated.
Thanks
Gail
* gsh### [at] monotixcoza * ERROR: COFFEE.COM not found *
* http://www.rucus.ru.ac.za/~gail/ * Insert cup and press any key *
My Software never has bugs, It just develops random features
>works. I tried
>isosurface {
> threshold 1
> sign 1
> pigment {Red}
Try this:
isosurface {
function { "helix1" <2,1,0.2,1,1,1,0> }
threshold 0
max_gradient 20 method 2
bounded_by {box {-10,10}}
sign 1
pigment {red 1} finish {ambient .4}
Most of the internal functions are designed to work with a threshold of
zero. By default, they're bounded by a small box, so you need to add a
bounding volume if you want to see anything interesting. I also added
the max_gradient 20 method 2 to eliminate some gaps in the result.
Finally, the docs for parameter 4 ("shape parameter") are useless, but
a little playing shows that it is the ratio of height to width for the
ellipses the "strands" are made out of. Zero is a bad number, and will
in fact crash on some architectures. Replacing it with a one gives
you a circular cross-section, which is what I assume you wanted. I'll
try to remember to fix this in the next version of the docs.
Ron Parker wrote in message <37ce9813@news.povray.org>...
>Try this:
>isosurface {
> threshold 0
> sign 1
Thanks, that's basically what I wanted.
Next question. Can I use the isosurface functions within media.
I seem to vaguely remember a discussion on that, can't remember when or
where
though
Thanks
Gail
Yes, they can be used in media, or in place of any other pattern. Just
use function {function stuff here} in place of the pattern name.
